[Offer Ended] VanDamme Blue Series Loudspeaker cable...
Thread Closed
Old 28-08-2006, 9:07 AM   #1
Assured Advertiser
Joe Fernand's Avatar
36,543, Level: 46
Points: 36,543, Level: 46 Points: 36,543, Level: 46 Points: 36,543, Level: 46
Activity: 20.3%
Activity: 20.3% Activity: 20.3% Activity: 20.3%
Thanks: Gave 205, Got 1,344
Lots of AVForums members are always enquiring about a well manufactured relatively affordable loudspeaker cable and this is the one that many folk have found to offer the best mix of quality vs. cost.
The industry standard VanDamme range of Blue Series Two core speaker cables feature fine stranded conductors and utilise the latest PVC composite jacket materials to provide the highest level of flexibility married with totally efficient signal transmission.
This range of cables is ideal for HiFi 'Stereo' and Home Theatre 'Multi channel' installations.
VanDamme use a higher purity oxygen free copper for the conductors which improves the ‘solderability’ and conductivity of the conductor resulting in faithful and transparent signal reproduction.
The overall jacket material is a neoprene heavy duty PVC composite that has an almost rubberised quality. This jacket is high pressure extruded over the 2 twisted inner conductors to create a robust, extremely flexible speaker cable.
• Three conductor sizes to suit your budget and application.
• Ultra pure oxygen free copper conductors for high efficiency signal transmission
• Composite jacket material for excellent flexibility
2 x 4.0mm Blue Series SRP £7.80/m - PowerBuy price £4.02/m
2 x 2.5mm Blue Series SRP £4.08/m - PowerBuy price £2.11/m
2 x 1.5mm Blue Series SRP £2.60/m - PowerBuy price £1.34/m
Prices are for un-terminated lengths - custom length 7.1 and 5.1 cable kits including 4mm Banana plugs or Spade connectors can be specified; please call for details.
Prices shown are Inclusive of VAT.
Prices shown are excluding UK delivery.
Best regards
Joe
Last edited by Joe Fernand; 01-03-2011 at 11:01 AM. Reason: New pricing - 01.03.2011
Old 10-09-2006, 4:27 PM   #2
3,049, Level: 12
Points: 3,049, Level: 12 Points: 3,049, Level: 12 Points: 3,049, Level: 12
Thanks: Gave 15, Got 0
Re: VanDamme Blue Series Loudspeaker cable...
[QUOTE=Joe Fernand;3388931]VanDamme Blue Series Loudspeaker cable...
>Next Working Day UK Insured delivery is £11.15 per order - up to 20Kg.
Joe ... do you offer any other postage options ... £11.15 is a tad expensive for a few m of cable ?
Old 23-09-2006, 12:56 PM   #3
3,811, Level: 14
Points: 3,811, Level: 14 Points: 3,811, Level: 14 Points: 3,811, Level: 14
Thanks: Gave 1, Got 6
Hi joe
Which mm cable would you recommend for Miller & Kreisel XENON 25 Tripole speakers
Cheers.
Old 23-09-2006, 7:16 PM   #4
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello Mission
Depending on the length of cable your running - the 2x1.5mm or 2x2.5mm will be ideal; personally I'd use the 2x2.5mm even on a short run.
Best regards
Joe
PS Tafflad - I'm working on a lower shipping cost option.
Old 23-09-2006, 8:18 PM   #5
3,811, Level: 14
You have PM
Old 25-09-2006, 1:32 PM   #6
4,411, Level: 15
Points: 4,411, Level: 15 Points: 4,411, Level: 15 Points: 4,411, Level: 15
Thanks: Gave 39, Got 36
Hi Joe, can you let me know when you have a cheaper delivery rate?
Old 25-09-2006, 2:08 PM   #7
7,383, Level: 20
Points: 7,383, Level: 20 Points: 7,383, Level: 20 Points: 7,383, Level: 20
Thanks: Gave 18, Got 38
Try your local Maplin store if you want to save on delivery.
andye2004 (25-09-2006)
Old 25-09-2006, 5:38 PM   #8
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello andye2004
We should have a lower cost Delivery option in place by end of play tomorrow.
Best regards
Joe
Old 25-09-2006, 9:06 PM   #9
4,411, Level: 15
Originally Posted by Joe Fernand View Post
Hello andye2004
Best regards
Joe
Can you post the cost when you know what it is and I'll have a think about how much I need.
Old 26-09-2006, 9:05 AM   #10
4,411, Level: 15
Hi Joe, any chance of a picture of the cable?
Old 27-09-2006, 10:14 AM   #11
4,411, Level: 15
Hi Joe, any news on the delivery cost yet? I'm pretty keen to get some on order.
Old 27-09-2006, 10:53 AM   #12
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello andye2004
If I use Royal Mail Special Delivery - UK Insured Next Working Day before 13:00 and assuming its the 2x2.5mm cable (unterminated) I can do.
Up to 9m - 6.69 GBP
Up to 19m - 8.69 GBP
Best regards
Joe
Old 28-09-2006, 8:28 PM   #13
5,506, Level: 17
Points: 5,506, Level: 17 Points: 5,506, Level: 17 Points: 5,506, Level: 17
Thanks: Gave 8, Got 4
Hello
I'd like to order some - how ?
Old 28-09-2006, 9:00 PM   #14
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello starkraving
You have a PM
Best regards
Joe
Old 30-10-2006, 8:38 PM   #15
3,778, Level: 14
Points: 3,778, Level: 14 Points: 3,778, Level: 14 Points: 3,778, Level: 14
Thanks: Gave 4, Got 1
Hi Joe,
Can you tell me how much it would cost for 2 x 5m lengths of 2.5mm with fitted banana plugs.
P.S Any chance of looking over that spec for me?
mattster (24-04-2008)
Old 01-11-2006, 9:11 AM   #16
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,859, Level: 38
Points: 24,859, Level: 38 Points: 24,859, Level: 38 Points: 24,859, Level: 38
Activity: 12.2%
Activity: 12.2% Activity: 12.2% Activity: 12.2%
Thanks: Gave 598, Got 1,311
Joe
what's the story with shipping costs to ireland?
Old 01-11-2006, 9:25 AM   #17
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello mossym
If its NI its the same as the rest of the UK - if its the Republic drop me a note with your requirements and we'll work you out a price.
Best regards
Joe
Old 10-11-2006, 5:35 PM   #18
2,106, Level: 10
Points: 2,106, Level: 10 Points: 2,106, Level: 10 Points: 2,106, Level: 10
Thanks: Gave 9, Got 5
How much for 2*4.5m terminated with banana plugs? How much without termination?
Cheers.
Old 14-11-2006, 10:45 PM   #19
jagdeepp's Avatar
9,721, Level: 23
Points: 9,721, Level: 23 Points: 9,721, Level: 23 Points: 9,721, Level: 23
Thanks: Gave 259, Got 161
Hi Joe, I'm interested in 1x 6mtr terminated on each end and 1x8mtr terminated on each end..its for my M.A RSFX rears.. wondering which thickness of cable will be best..
Kindly quote me so as to include postage.
Look forward to hearing from you.
Regards
Jag
Old 15-11-2006, 5:04 PM   #20
jagdeepp's Avatar
9,721, Level: 23
Joe, ignore my message above. .not having heard from you i went out and purchased some cable with my speakers.
Regards.
Old 15-11-2006, 5:35 PM   #21
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello jagdeepp
My PM box was on a major go slow over the last couple of days - not sure if its at my end or to do with the latest Forum update, I've only just received your message.
Good you got sorted.
Best regards
Joe
Old 04-12-2006, 3:44 PM   #22
Y15HAL's Avatar
3,231, Level: 13
Points: 3,231, Level: 13 Points: 3,231, Level: 13 Points: 3,231, Level: 13
Thanks: Gave 1, Got 30
Hi Joe,
I need 23 Metres of the 2.5mm Cable. How much will you charge including delivery and how soon can i have it?
Vishal
Old 04-12-2006, 4:27 PM   #23
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello Y15HAL
You've missed tonight's Post - it will have to be tomorrow now! I'll PM details on the costs.
Best regards
Joe
Old 05-12-2006, 3:23 AM   #24
taoyeah
Posts: n/a
hi. joe. i want to order 40m (2 x 2.5mm) ,how much is it including shipping to New York?
Old 05-12-2006, 8:07 AM   #25
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello taoyeah
I'll work out a shipping cost and PM you the details later today.
Best regards
Joe
Old 05-12-2006, 8:11 AM   #26
6,023, Level: 18
Points: 6,023, Level: 18 Points: 6,023, Level: 18 Points: 6,023, Level: 18
Thanks: Gave 3, Got 51
Hi Joe,
Can this cable be painted well/easily (just need last couple of metres white)?
Also, can you beat other sites? Clearly AV have much cheaper prices across the board, especially when factoring in free delivery (Special Delivery or next day courier) for orders over £45. I can get 25m of 2.5mm2 for £45, but it would be £60 with the powerbuy. I will need this, maybe a bit more depending on what you can do.
Cheers,
Dingwall.
Old 05-12-2006, 9:33 AM   #27
Y15HAL's Avatar
3,231, Level: 13
Originally Posted by dingwall View Post
Hi Joe,
Cheers,
Dingwall.
I found it cheaper elsewhere too, and this included next day delivery. If the price can be dropped by Joe, then i will be purchasing promptly!
Old 05-12-2006, 1:35 PM   #28
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello dingwall
I have seen the cable being painted - though I guess you have to be aware of what's in the paint in case it attacks the neoprene outer layer of the cable.
Another option is to put the cable in a white spiral sleeve - a couple of meters of sleeve is relatively inexpensive.
In terms of pricing I'll have a look at it - though I can't see where these guys are making any money; especially so with the FREE delivery on orders over 45.00 GBP.
Best regards
Joe
Old 06-12-2006, 12:18 AM   #29
taoyeah
Posts: n/a
hi, joe , u found out the price yet?
and i dont need any plug.
Old 06-12-2006, 12:49 AM   #30
Assured Advertiser
36,543, Level: 46
Activity: 20.3%
Hello taoyeah
You have a PM.
Joe
Thread Closed
