Component cable - Broadcast Reference Series – Belden 7710A
Old 25-11-2003, 8:10 PM   #1
Assured Advertiser
21,242, Level: 35
Points: 21,242, Level: 35 Points: 21,242, Level: 35 Points: 21,242, Level: 35
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 58, Got 205
Broadcast quality component cables manufactured using Belden 7710A VideoFlex® Snake Cable for Precision Analogue and Digital Video.
Not available to buy anywhere else in the UK, this cable is specially imported from Belden USA.
Belden 7710A is a three-conductor version of Belden's famous 1694A video coax, the best of the new breed of high-bandwidth precision video cables.
Engineered for critical video applications, its exceptional bandwidth and low-loss characteristics make it perfect for use in carrying component video signals, even over long distances.
Belden 7710A is made of three 1694A coaxes, coloured red, green and blue, and wrapped together in a black outer jacket, making a bundle approximately 3/4 inch diameter. (20mm)
The cable is surprisingly flexible for it’s size
The three cores in the 7710A are tightly twisted to provide superior noise rejection, compared to three loose cores.
The cores of the 7710A are all the same length. (very important)
Component cables using three separate cables are very hard to produce, trying to keep the cores all the same length.
Termination is with Canare impedance matched RCA phono connectors.
These are high quality crimped connectors, considered to be the best for digital and Video applications.
Also available are Canare BNC connectors at no extra cost, for use with plasmas with BNC inputs etc.
All cables are hand assembled to the highest possible standards using Canare specialist tooling for the cable stripping and connector crimping. The Canare TC-1 crimp tool has been calibrated to provide a crimp connection that is exactly to Canare specifications.
caig products are used to clean and treat the core of the coax and crimp pin during the assembly process.
Nothing left to chance, perfection every time.
Prices
1 Metre £XX
2 Metre £??
3 Metre £??
4 Metre £??
5 Metre £??
6 Metre £??
7 Metre £??
8 Metre £??
9 Metre £??
10 Metre £??
(thread updated with new reduced prices on 19/02/06)
Prices include UK delivery, no hidden charges ! , and is an absolute bargain for such a high quality and expensive Belden cable !!
The cable is HUGE in diameter compared to other cables, so look at the photos below comparing this 7710A cable to individual 1694A cable.
Everyone that has tested the cable for the last week, has been impressed by the performance and build quality
Might cost more than other cables, but that Plasma or projector is worth it.
Performance of this cable is absolutely superb !
Probably the last component cable you will ever need to buy.....
Post here to order, or with any questions.
Mark.
Yaka (07-03-2008)
Old 25-11-2003, 8:11 PM   #2
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Old 25-11-2003, 8:11 PM   #3
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Old 25-11-2003, 8:16 PM   #4
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
(Edited some old photos from here)
Mark.
Old 25-11-2003, 8:19 PM   #5
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
I have had one of these on Test in the hive for a week or so now, I will write more tomorrow but it is the best I have seen.
Cabes come no better IMHO
Old 25-11-2003, 9:53 PM   #6
Founder
Stuart Wright's Avatar
146,944, Level: 92
Points: 146,944, Level: 92 Points: 146,944, Level: 92 Points: 146,944, Level: 92
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 902, Got 4,628
4 meter job, please.
Old 26-11-2003, 7:50 AM   #7
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Hello Spectre,
Sent you an email,
thanks,
Mark.
Old 26-11-2003, 12:41 PM   #8
eatstatic's Avatar
5,322, Level: 17
Points: 5,322, Level: 17 Points: 5,322, Level: 17 Points: 5,322, Level: 17
Thanks: Gave 51, Got 37
Hi Mark,
Would like to order a cable from you. Either going to be a 4m or 5m cable required.
Will double check size required this week and confirm if that is ok with you.
Thanks.
Old 27-11-2003, 1:21 AM   #9
andro
Posts: n/a
Being a beginner, I'm not sure what I'm going to need yet as I still haven't decided which TV and DVD player to go for. I will be buying a Component progressive dvd and tv though. I've been looking at prices for IXOS and QED component cables and seen them go as high as £99 for a 1 metre QED SCR-CV1 component cable. Is the Belden still better than this cable?
Thanks.
Old 27-11-2003, 8:41 AM   #10
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Hello Eatstatic,
Let me know the length of cable you need, you will be happy with it
Hello Andro,
It is the Canare 75 ohm phono connectors I use that make these cables so good. There are many makes of 75 ohm coax around, but hardly any with 75 ohm phono connectors fitted.
The Belden 7710A is a perfect cable, so are the connectors used
Never compared it to the QED SCR V1, that is a silver plated copper cored coax, but not sure about the connectors used, the canares takes some beating. Would be an interesting comparison.
I have an idea for a comparison of cables, will be in a different thread next week. Maybe a box of cables for home trial, component, digital coax, subwoofer cable etc.
thanks,
Mark.
Old 27-11-2003, 9:33 AM   #11
Eminent Member
Ian J's Avatar
71,654, Level: 65
Points: 71,654, Level: 65 Points: 71,654, Level: 65 Points: 71,654, Level: 65
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 3,114, Got 4,720
Andro,
When The Beekeeper says that it is the best cable that he has ever seen, you can be sure that it is something special.
Old 27-11-2003, 9:38 AM   #12
Illustrious Member
48,568, Level: 53
Andro
Mark is under playing the quality of the product here, if I was doing this I would do it no different to Mark and yes I have IXOS, QED, Chords and many of the other names at home. Some are fine (but expensive) but this is the Rolls Royce of cables at beer money. A no brainer This will simply be the last cable you ever buy
Old 27-11-2003, 11:29 AM   #13
Tim Cooper's Avatar
9,776, Level: 23
Points: 9,776, Level: 23 Points: 9,776, Level: 23 Points: 9,776, Level: 23
Activity: 8.8%
Activity: 8.8% Activity: 8.8% Activity: 8.8%
Thanks: Gave 196, Got 62
Arrow Quality.....
Hi all,
Can i chip in here.
I've been using Mark's cables for well 18 months, my whole cinema is now using his cables including the mains.
If anyone has any doubts as to the benefits of using his cableing in one word...DON'T...these are HAND BUILT cables using the best cables & plugs money can buy, you will not find a better quality cable at this price point this side of the Atlantic.
I keep seeing people advertise for component/rgb/co-axial et-al "must be cheap" come on peeps your 3-4 grand PJ/plasma/rear PJ TV deserves better.
Cheers.
Tim. (biased.....you bet )
Old 27-11-2003, 11:43 AM   #14
3,445, Level: 13
Points: 3,445, Level: 13 Points: 3,445, Level: 13 Points: 3,445, Level: 13
Hi Mark
I'll have 8 meters please.
Mike
Old 27-11-2003, 6:53 PM   #15
Niraj
Posts: n/a
Hi Mark,
I am interested in getting this cable. Would appreciate your advice please.
Am wondering whether to buy a 1m or 2m cable. My Hitachi media box sits on top of my DVD player, so 1m should do fine, I think, but being the cautious chap I am, was wondering if buying 2m would be a good idea "just in case".
My question is, will the length of tha cable have any effect on the quality of the picture to the human eye??
Niraj
Old 27-11-2003, 7:54 PM   #16
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Hello Mike A,
Thanks for the order
I have sent you an email.
£120 for 8 metres.
Mark.
Old 27-11-2003, 8:05 PM   #17
andro
Posts: n/a
Hello again....
Mark thankyou for your reply regarding the fact it is the plugs you use that also help the fact this cable is the mutts nuts.
But being a complete newbie I'm afraid I have to ask the question from a newbies point of view who has never owned a widescreen, plasma, lcd, rpt or likwise as of yet... Would I honestly notice the difference from say a IXOS or THOR or QED cable compared the cables your selling... I know I probably would if i saw 2 tv's side by side, but I have to look at cost and I can only trust your honest professional opinions, but I do and I thankyou for that. Just its hard to know without seeing or actually knowing, if you see what I mean. hmmmm... Considering I probably won't buy my TV until after christmas I hope to come back and buy a cable from you, so would be nice to know if you can get more incase im too late to order one
Thanks.
Andy.
Old 27-11-2003, 8:25 PM   #18
11,607, Level: 25
Points: 11,607, Level: 25 Points: 11,607, Level: 25 Points: 11,607, Level: 25
Thanks: Gave 8, Got 28
With these cables you get what you pay for, with consumer cables like IXOS, THOR, QED, you don't, it's that simple
Old 27-11-2003, 8:30 PM   #19
andro
Posts: n/a
yeah thats life i suppose....
Just have to try it and see.
Old 27-11-2003, 9:30 PM   #20
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Hello Andro,
I doubt you will get better for the price.
Beekeeper sums it up really well, top quality for beer money.
When you get the new TV, I will still have some, you will not miss out
If the same cable was sold by a leading AV brand/marketing name, people would pay many times the price and still be happy...
Mark.
Old 27-11-2003, 9:43 PM   #21
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Niraj
Hello Niraj,
I really doubt you will notice any loss comparing 1M to 2M.
But remember that the cable is a large diameter, so having a spare metre hanging behind the AV rack just for the sake of it might not be the best way. Depends how much room you have really.
Hope that helps you decide,
Mark.
Old 27-11-2003, 10:42 PM   #22
Niraj
Posts: n/a
Hi Mark,
Thanks fo rthe reply.
I would like to buy a 1m cable please.
Niraj
Old 28-11-2003, 8:45 AM   #23
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Hello Niraj,
Sent you a PM,
Thanks for the order,
Mark.
Old 28-11-2003, 9:18 AM   #24
Mr THX's Avatar
5,510, Level: 17
Points: 5,510, Level: 17 Points: 5,510, Level: 17 Points: 5,510, Level: 17
Thanks: Gave 22, Got 32
Mark
What are the chances of having one on your fine cables made up with 3 Component connectors on one end (as your picture) and a VGA plug at the other end (as my picture)
Old 28-11-2003, 9:40 AM   #25
7,409, Level: 20
Points: 7,409, Level: 20 Points: 7,409, Level: 20 Points: 7,409, Level: 20
Thanks: Gave 17, Got 9
Hi Mark, I would like to purchase a 9 metre cable from you.
Regards Will.
Old 28-11-2003, 1:52 PM   #26
9,943, Level: 23
Points: 9,943, Level: 23 Points: 9,943, Level: 23 Points: 9,943, Level: 23
Thanks: Gave 0, Got 5
i take it this cable will still be available after crimbo. i am after 6 meters but will have to wait till a have got everyones crimbo pressies
also what other cables do you make? ie.. speaker-svid-scart-vga-optical so on
Dc
Old 28-11-2003, 8:36 PM   #27
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Hello GrannySmith,
I have sent you a message with payment details, thanks for the order.
Mark.
Old 28-11-2003, 8:54 PM   #28
vonhosen's Avatar
5,917, Level: 18
Points: 5,917, Level: 18 Points: 5,917, Level: 18 Points: 5,917, Level: 18
Thanks: Gave 0, Got 17
Originally posted by Mr THX
Mark
If Mark can't do that you might want to look at bettercables . I believe Joe Fernand on these forums is a dealer for them in the UK.
Old 28-11-2003, 9:46 PM   #29
Assured Advertiser
21,242, Level: 35
Activity: 2.7%
Mark
Hello Mr THX,
The Belden 7710a used for the cables in this thread is far too large to fit into a VGA plug.
Would need to be a much smaller cable, such as the RG179 size that Vonhosen has linked to.
I am fairly sure I have some of the cable, can you let me know the length you need, I will have a look and let you know.
(You can mail me from my profile)
Thanks,
Mark.
Old 28-11-2003, 10:08 PM   #30
vonhosen's Avatar
5,917, Level: 18
Oh & Mark
I'd like to order a 6.5m cable please
