SAW kinowelt release
Old 17-06-2008, 10:05 AM   #1
2,910, Level: 12
Points: 2,910, Level: 12 Points: 2,910, Level: 12 Points: 2,910, Level: 12
Thanks: Gave 35, Got 12
hello people, this one arrived me yesterday, but it doesn`t work. on the E1 doesn`t work at all, says noplay on the display, while on the xbox 360, it does play the kinowelt intro. once it even did play the menu, it was the second time I put it in, but when I choose online then it started giving me problems. since then it just plays the said logo, then it goes black screen and shows nothing. the console can open and close trays and be turned off from the remote. otherwise it is unresponsive totally. is there something I can do? thanks guys
Old 18-06-2008, 1:03 PM   #2
2,910, Level: 12
Re: SAW kinowelt release
problem solved with an update.
