Spiderman 3 Blu-Ray no 5.1 sound on PS3?
Old 07-01-2008, 11:03 PM   #1
2,637, Level: 11
Points: 2,637, Level: 11 Points: 2,637, Level: 11 Points: 2,637, Level: 11
Thanks: Gave 20, Got 11
Can anyone tell me how to get Spiderman3 to output a Dolby digital 5.1 soundtrack via an optical connection?
Other blu-ray discs output it no problem.
I have tried this on two different sound systems, an aincient pioneer and a brand new sony str-ks1100, on both systems I get stereo and sw but thats it.
Does the Spiderman disc contain a std 5.1 soundtrack or is it only the Dolby true soundtrack.
Do I need to output the sound via Hdmi as well?
Any suggestions gratefully received
(just when i thought I knew what I was doing!)
On a slight tangent the standard Spiderman 3 would not do it either.
Old 07-01-2008, 11:37 PM   #2
Adam_uk's Avatar
7,343, Level: 20
Points: 7,343, Level: 20 Points: 7,343, Level: 20 Points: 7,343, Level: 20
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 48, Got 87
Re: Spiderman 3 Blu-Ray no 5.1 sound on PS3?
The US versions do not have DD.
Spidy 3 has PCM and Tru HD, 1 & 2 have Tru HD only.
I would have thought this would be down mixed to DD.
Does your amp have HDMI?
Old 07-01-2008, 11:56 PM   #3
Ron240's Avatar
9,456, Level: 23
Points: 9,456, Level: 23 Points: 9,456, Level: 23 Points: 9,456, Level: 23
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 104, Got 258
I just checked my disc,and the default audio is Dolby TrueHD 5.1.
I have my PS3 connected to my Denon receiver via Optical,which plays it as Dolby Digital 5.1 no problem at all.
Old 08-01-2008, 9:49 AM   #4
2,637, Level: 11
Thx for the info guys, I have had a look at the small print and there seems to be an English pcm 5.1 track so will try and set that up.
The Sony system has 2 hdmi sockets will try that too.
Would the configutation go: ps3 -hdmi to sony(to pick up sound).
: sony -hdmi to projector( to pick up video? )
thx in advance
Old 08-01-2008, 11:15 AM   #5
Ron240's Avatar
9,456, Level: 23
Activity: 3.4%
I think there has to be something wrong with your basic configuration,because it should definitely play as DD 5.1 by default through Optical connected to any suitably equipped receiver.
I checked the PCM 5.1 (uncompressed) audio track,and that only comes through as 2 channel via Optical,but i believe this would work through HDMI to a suitably equipped receiver.
Old 08-01-2008, 2:06 PM   #6
2,637, Level: 11
All other discs are fine, which is what's throwing me!
Old 08-01-2008, 2:21 PM   #7
Ron240's Avatar
9,456, Level: 23
Activity: 3.4%
In that case...it is a strange one...
The only thing i can tell you for sure is,mine plays exactly the way you would expect it to. PS3 - Denon1907 via Optical cable. Dolby TrueHD 5.1 on the Blu-ray,playing as DD 5.1 through my receiver.
Old 09-01-2008, 1:29 PM   #8
Illustrious Member
Indiana Jones's Avatar
30,255, Level: 42
Points: 30,255, Level: 42 Points: 30,255, Level: 42 Points: 30,255, Level: 42
Activity: 29.5%
Activity: 29.5% Activity: 29.5% Activity: 29.5%
Thanks: Gave 53, Got 1,271
Same here, TrueHD and PCM tracks playback as DD5.1 through Optical with the PS3 set to Bitstream.
Old 09-01-2008, 2:33 PM   #9
Ron240's Avatar
9,456, Level: 23
Activity: 3.4%
Are you absolutely sure your uncompressed PCM track plays as multi-channel audio via Optical? I didnt think this was possible.
I thought you had to use HDMI for this.
Old 09-01-2008, 9:49 PM   #10
Illustrious Member
30,255, Level: 42
Activity: 29.5%
Just checked and you are correct, when I selected the Uncompressrf 5.1 track my amp switched to ProLogic but when a TrueHD track is selected it is output as DD5.1
Old 10-01-2008, 12:29 AM   #11
2,637, Level: 11
I flicked through the language settings and they all went into DD right away, I think on option 8 I found an English DD 5.1 track and it worked!!
Very user friendly not!!
Anyway thx again for the pointers guys
Old 10-01-2008, 12:48 AM   #12
Ron240's Avatar
9,456, Level: 23
Activity: 3.4%
I only have 7 different options in the language section on my disc. Apart form the 2 already mentioned,and the foreign languages....there is an English Audio Descriptive Service option,which although it is in DD5.1,you definitely dont want to be using that one.
Hope you have it sorted though.
Old 14-01-2008, 1:35 PM   #13
3,075, Level: 13
Points: 3,075, Level: 13 Points: 3,075, Level: 13 Points: 3,075, Level: 13
Thanks: Gave 6, Got 0
Hi guys. I have a Sony Home Theatre system (a DAV-DZ830W) and im struggling to find the best audio output for Spidey 1,2 and 3.
I have my ps3 connected to the Cinema system via optical and the PS3 connect to the TV via HDMI.
I've only tested Spidey 1 but if I leave the sound on PCM Linear it outputs True HD 5.1 but it only sounds like its coming out the front 3 speakers If i change it to bitstream it says its outputting in DD MultiChannel but it still doesn't sound like surround sound.
Any ideas what I should be doing to get the optimal surround sound and will the method work for all three flicks as I have the Hi Def trilogy. I can change the sound on the cinema system to things like pro logic 2, multi and theres the sony studio EX settings. But im clueless. The flicks just sound really dead. Like DVD. lol.
Many thanks in advance!!
Old 14-01-2008, 3:15 PM   #14
chic's Avatar
16,935, Level: 31
Points: 16,935, Level: 31 Points: 16,935, Level: 31 Points: 16,935, Level: 31
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 153, Got 884
IF you are outputing over optical, the ps3 should be set bitstream over optical and not pcm, if done correctly you should get standard dolby digital 5.1.
SpiderMike (14-01-2008)
Old 14-01-2008, 4:02 PM   #15
3,075, Level: 13
It says dolby digital but Multi speaker. Not 5.1. Only says 5.1 when I change to PCM.
Is multi channel just another way the ps3 says 5.1 then?
Old 14-01-2008, 4:11 PM   #16
32,091, Level: 43
Points: 32,091, Level: 43 Points: 32,091, Level: 43 Points: 32,091, Level: 43
Thanks: Gave 116, Got 658
Yes.
Old 14-01-2008, 4:27 PM   #17
chic's Avatar
16,935, Level: 31
Activity: 5.7%
in a way yes,
Old 14-01-2008, 4:43 PM   #18
3,075, Level: 13
Well if thats the best I can get then that'll have to do. Many thanks to those that responded.
Old 14-01-2008, 5:36 PM   #19
Ron240's Avatar
9,456, Level: 23
Activity: 3.4%
While i dont completely understand your previous post to this one,can you confirm that you are now getting 5.1 sound?
If you're not,then its just a simple setting that is wrong....but if you are,then how much better do you want it?
Old 15-01-2008, 12:09 AM   #20
3,075, Level: 13
I have the BD set to True HD, the PS3 set on bitmapping and when i press select in the top right hand corner it has dolby digital multichannel.
So u tell me. lol.
Old 15-01-2008, 8:52 AM   #21
stuart1976's Avatar
6,666, Level: 19
Points: 6,666, Level: 19 Points: 6,666, Level: 19 Points: 6,666, Level: 19
Thanks: Gave 55, Got 181
Smile Re: Spiderman 3 Blu-Ray no 5.1 sound on PS3?
So u tell me. lol.
Yes it is outputting in DD 5.1, I have my PS3 connected to my Amp by Optical Cable and the PS3 set to Bitstream.
I have Spider-Man 3 and when I tested this last night to check, when I played the Uncompressed track, my Amp only displayed PCM 2.0 but when I played the True HD track my Amp displayed Dolby Digital 5.1 and I had the Blue multi-channel light lit up.
As my Amp cannot decode True HD it will output the core DD 5.1 sound.
SpiderMike (15-01-2008)
Old 15-01-2008, 9:13 AM   #22
3,075, Level: 13
So shall i keep that setting for all three films?
Old 15-01-2008, 6:11 PM   #23
Illustrious Member
30,255, Level: 42
Activity: 29.5%
Yep that is the setting you want.
Old 15-04-2008, 6:58 PM   #24
3,075, Level: 13
This is kind of a follow up to my earlier query.
With the release of the 2.30 Firmware on the PS3 comes DTS-HDMA etc etc.
Do I need to start using linear or stick to bitmap still. The only reason I ask is that if I switch to linear, the display (shown by pressing select) shows the sound as DTS-HDMA but it still sounds like its only coming out of the front 3 speakers. The little DTS symbol on the Home Theatre system also disappears. If I switch to bitmap the display changes to just plain old DTS and sound comes out of all 5 and the DTS symbol is again seen onthe Theatre system.
Which should I be using?
Old 15-04-2008, 7:16 PM   #25
Ron240's Avatar
9,456, Level: 23
Activity: 3.4%
I assumed the last time you used this word, you had simply made a mistake.
"bitmap" is an image file format, so you must mean bitstream.
The latest software update to the PS3 is only of any advantage to you, if you connect your PS3 directly to your AV Receiver using an HDMI cable.
Old 16-04-2008, 3:54 AM   #26
3,075, Level: 13
Fair play.
So what's the best settings I can get by connecting with an optical cable?
Old 18-04-2008, 3:34 PM   #27
digitalsafari's Avatar
5,250, Level: 17
Points: 5,250, Level: 17 Points: 5,250, Level: 17 Points: 5,250, Level: 17
Thanks: Gave 17, Got 48
On BD if you have a TrueHD track there is normally also be a DD version of the same track for compatability as TrueHD decoding is not mandatory on BD players.
If you have your PS3 audio out set as Optical out with DD 5.1 decoding checked.
Then if you select TrueHD in the BD audio menu it will be overidden and ouput the 5.1 DD compressed track.
If you have your PS3 audio out set as Optical with DD 5.1 un-checked and 2 channel PCM checked.
Then if you select TrueHD in the BD audio menu it will output a 2 channel downmix of the TrueHD track as PCM.
To get 5.1/7.1 multichannel PCM or decoded TrueHD/DTS-MA out of the PS3 you need to use HDMI and a suitable HDMI-in Amp.
Old 10-06-2008, 6:56 PM   #28
2,370, Level: 11
Points: 2,370, Level: 11 Points: 2,370, Level: 11 Points: 2,370, Level: 11
Question Re: Spiderman 3 Blu-Ray no 5.1 sound on PS3?
Hey everyone I just had a quick question. I'm using an old Denon AVR-3600 that only supports DD 5.1 decoding not DTS and definetly not the newer codecs. I'm running a PS3 as my blu-ray player with HDMI to the TV and an optical toslink to the receiver. I have it set to output bitstream and checked dolby digital and the standard 2 channel PCM.
Most of my experiences with Blu-ray movies are they either have a DD 5.1 english soundtrack or a Dolby TrueHD. In the case of the latter I have come to believe that a DD 5.1 track is hidden with the independent TrueHD track and thus I get DD 5.1 to my AV receiver. Is this always the case and is it the case with Spider-man 3 which I want to purchase.
Also is there anything that I can do if the only audio track is DTS-HDMA or DTS. Will the PS3 decode DTS-HDMA and then encode it into DD 5.1 and send it out or is that just crazy talk. I just want to keep my Denon as it sounds amazing and was a heck of a lot of cash 10 years ago.
