'King Kong' HD DVD question
Old 15-03-2007, 10:16 AM   #1
Illustrious Member
Pecker's Avatar
43,939, Level: 51
Points: 43,939, Level: 51 Points: 43,939, Level: 51 Points: 43,939, Level: 51
Activity: 16.9%
Activity: 16.9% Activity: 16.9% Activity: 16.9%
Thanks: Gave 2,682, Got 1,888
How do I access u-control on the US King Kong disc on my Toshiba HD-E1?
I've gone into the menu mid-film, and clicked on u-control, to turn it on.
It shows as being 'on', but...that's it.
What do I do next?
Sorry for being thick.
Steve W
Old 15-03-2007, 5:41 PM   #2
Donnacha's Avatar
9,117, Level: 22
Points: 9,117, Level: 22 Points: 9,117, Level: 22 Points: 9,117, Level: 22
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 315, Got 127
Re: 'King Kong' HD DVD question
when a little icon appears at the side just press enter on the remote (i think!). That should pop up the available items, e.g. stills, video, info etc. Then you can use the remote arrow buttons to pick the one you want, pressing enter again.
Its a neat little gimmick, although I haven't really watched any of it yet!
Old 19-04-2007, 2:25 PM   #3
Conspicuous Member
domtheone's Avatar
15,026, Level: 29
Points: 15,026, Level: 29 Points: 15,026, Level: 29 Points: 15,026, Level: 29
Thanks: Gave 327, Got 333
Could anyone confirm if both the UK and US discs have this U Control thing.
Also, do the HD-DVD's of KK that were given away with HD-DVD Drives have this feature as well?
TIA
Old 19-04-2007, 2:50 PM   #4
Bald Monkey's Avatar
30,605, Level: 42
Points: 30,605, Level: 42 Points: 30,605, Level: 42 Points: 30,605, Level: 42
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 1,468, Got 1,105
AFAIK,
And hopefully someone will corect me if I'm worng...
The US Freebie has U-Control etc.. The US Retail version also has this, as does the UK retail version.
However the UK freebie version does not for some reason
Old 19-04-2007, 4:04 PM   #5
Conspicuous Member
domtheone's Avatar
15,026, Level: 29
Well i'm more the wiser for that so thank you
Old 19-04-2007, 6:55 PM   #6
ScottEvil30
Posts: n/a
UK Retail doesn't have it.
