Anyone had problems with Terminator: the sarah conner chronicles season 2?
Old 21-11-2009, 4:16 PM   #1
Ewan154's Avatar
14,672, Level: 29
Points: 14,672, Level: 29 Points: 14,672, Level: 29 Points: 14,672, Level: 29
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 415, Got 47
Question Anyone had problems with Terminator: the sarah conner chronicles season 2?
Has anyone else had any problems with the Terminator: the sarah conner chronicles season 2? I have been having problems with disk 1. The picture keeps breaking up. Even my replacement disk does the same.
i'm using a Panasonic DMP-BD35EB-K Profile 2 player and the firmware is up to date.
Old 21-11-2009, 5:21 PM   #2
5,906, Level: 18
Points: 5,906, Level: 18 Points: 5,906, Level: 18 Points: 5,906, Level: 18
Thanks: Gave 22, Got 131
Yes my discs are breaking up at certain points as well. Good to know its not just me. Tried it on 2 PS3's & a sony S360 player. I looked it up on google and it is happening in Australia as well. Seems to be a mastering error & so the only hope is that they use a new master for future discs made. I may get my money back & wait a bit or contact Warner Bros UK to get a replacement in the future?
Regards
Old 21-11-2009, 7:28 PM   #3
Ewan154's Avatar
14,672, Level: 29
Activity: 1.0%
Is it only disk 1 that you are having problems with? I'm only having problems with disk 1, all the rest of the disks work fine.
Old 21-11-2009, 7:33 PM   #4
dav-t's Avatar
3,313, Level: 13
Points: 3,313, Level: 13 Points: 3,313, Level: 13 Points: 3,313, Level: 13
Thanks: Gave 32, Got 160
I have a panny 55 MR had no probs at all & sold it on (regA)
Old 21-11-2009, 7:38 PM   #5
mentasm's Avatar
8,968, Level: 22
Points: 8,968, Level: 22 Points: 8,968, Level: 22 Points: 8,968, Level: 22
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 16, Got 465
If you post the specific episodes/times and I'll check. I've watched a few eps so far and not had any problems.
Old 24-11-2009, 6:05 AM   #6
5,906, Level: 18
Its really just disc 1. I think the region A (USA) version might be fine though if thats what some of you guys are watching, not 100% sure though. Which would explain you not seeing any faults? The region B (UK) version is botched at points on episode 1, poss 2, 3 & also episode 8 (minor breakup) on disc 2.
Regards
