Sony RDR HXD860 Timer record problem
Old 07-05-2009, 11:07 AM   #1
4,723, Level: 16
Points: 4,723, Level: 16 Points: 4,723, Level: 16 Points: 4,723, Level: 16
Has anyone come across this before - about once a week (just when you need it to work) after selecting a program to record the timer cancels itself, no matter what channel etc any timer recording attempted will go through the motions and cancel itself at the end.
The only way I've found to get around it is to unplug the power to the unit then plug it back in again, just switching on/off has no effect.
Manual recording will work - just a problem with the timer recording.
Old 07-05-2009, 5:54 PM   #2
1,815, Level: 9
Points: 1,815, Level: 9 Points: 1,815, Level: 9 Points: 1,815, Level: 9
Thanks: Gave 7, Got 7
Re: Sony RDR HXD860 Timer record problem
Is this on HDD or DVD recordings ?
If on DVD look to see if you have enough room to record the program on the disc ?
Is anyone is the room when this stops recording ?
Remove the batteries from remote to see if it's sending out info on its own ?
Try disconnecting all leads except mains and the aerial to see if any other device is talking to the recorder .
Hope this helps ?
Old 08-05-2009, 2:34 PM   #3
4,723, Level: 16
Should have said HDD recording.
Use the remote to program via GUI on screen.
Old 08-05-2009, 2:45 PM   #4
Senior Moderator
80,624, Level: 69
Points: 80,624, Level: 69 Points: 80,624, Level: 69 Points: 80,624, Level: 69
Activity: 53.4%
Activity: 53.4% Activity: 53.4% Activity: 53.4%
Thanks: Gave 1,215, Got 3,002
Check that your clock time and date is staying accurate and updated.
It may be going awry , then resetting after you disconnect.
Old 08-05-2009, 9:50 PM   #5
1,705, Level: 9
Points: 1,705, Level: 9 Points: 1,705, Level: 9 Points: 1,705, Level: 9
I've had a similar problem - the HDD is only recording 30 mins or so of any timer settings. Fine for short progs, but I missed half of Ashes to Ashes as a result. Only started happening in the last week or so. Big problem on an otherwise great machine. Any help gratefully received.
Old 03-03-2010, 6:13 PM   #6
4,577, Level: 16
Points: 4,577, Level: 16 Points: 4,577, Level: 16 Points: 4,577, Level: 16
Activity: 14.0%
Activity: 14.0% Activity: 14.0% Activity: 14.0%
Thanks: Gave 33, Got 26
I have the same issue as well.....and it conicides with the recent digital retun e My mate has the same machien and same issue....Anyone else....looks like this is a fault !!!!
Old 03-03-2010, 10:17 PM   #7
JH4 JH4 is offline
9,761, Level: 23
Points: 9,761, Level: 23 Points: 9,761, Level: 23 Points: 9,761, Level: 23
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 67, Got 181
Here is the answer >
http://www.avforums.com/forums/dvd-b...oblems-15.html
Check out page 14.
Powered by
 Latest popular product prices
LG DRT389H
7 prices from
 £113.60 Click to show/hide the offers
Toshiba DR20
2 prices from
 £136.64 Click to show/hide the offers
Toshiba DVR20
5 prices from
 £181.54 Click to show/hide the offers
LG RHT497H 160GB
4 prices from
 £189.95 Click to show/hide the offers
Panasonic DMR-EX773 160GB
4 prices from
 £209.03 Click to show/hide the offers
Sony VRD-MC6
1 price
 £223.99 Click to show/hide the offers
LG RHT498H 250GB
3 prices from
 £209.95 Click to show/hide the offers
Panasonic DMR-EZ49VEGK
8 prices from
 £226.60 Click to show/hide the offers
 Updated February 9th at 5:30am. Prices include delivery.
