| Re: Sony RDR-HXD560 Recording Problem
Welcome to the forum.
This is the first problem of this nature I've heard about.
All I can suggest is trying a much longer power down of at least 20 minutes , maybe even overnight to clear out any corruption which may be lurking in buffers.
Also, have you noted if the problem applies to specific channels - or is it all channels?
You could consider a rescan for channels.
There are continual changes going on in Freeview broadcasting and this may be causing some problems.
