Originally Posted by music Further to the last very helpful post. Do any of these machines allow you to copy recorded material from the HD of the recorder to an external device - eg. external HD drive or usb stick. |
No. It is almost universally restricted.
Originally Posted by music If so, could you then copy it back to the HD of the dvd recorder at a later date or play the file direct from an external HD. |
You will find that it can be very difficult to guarantee getting a hard disc to work with any machine.
You are obviously looking for a flexibility that just does not exist in this area of the marketplace.
The reason is simple enough: The manufacturers do not want you doing this so they will not provide the facility.
Nearly all file transferring facilities are one way only.
What facilities that are provided are often problematic and restricted in many ways.
A further note on the Pioneers, which have perhaps the most flexibility... and for which you have to pay a Premium....We've had a few complaints that the transfer of DivX to the HDD - which HAS to be done to be watchable, is SO slow as to make the capability pointless.
Originally Posted by music (Incidentally, I'm not sure what format a HDD recorder saves material in - is it MP4 or something like that? |
It is MPEG2 - for the simple reason that MPEG2 is the de facto video file standard for DVD - so everything that comes into these machines is converted to it in preparation for laying onto a DVD...[ apart from the discrete file handling types like DivX / Wav / Jpeg / MP3 ]
