Pioneer dvd r error
Old 08-01-2009, 3:42 PM   #1
1,959, Level: 10
Points: 1,959, Level: 10 Points: 1,959, Level: 10 Points: 1,959, Level: 10
Pioneer dvd r error
hi guys every time i try to burn a vob file on to dvd i get a error
dvd r unspecified recorder error
im using nero 9
burn normal cd is ok only happens when i try to burn dvd plz help
log file
********** Nero Recode **********
Version: 2.5.6.0
Project type: Copy entire DVD
Compilation name: Defiance 2008 D
Target size: DVD5 (2282925)
16:30:15 File LangStreamPatcher.cpp, Line 56
Command table patching started...
16:30:15 File LangStreamPatcher.cpp, Line 135
All tables successfully patched!
Burn settings:
Target: PIONEER DVD-RW DVR-216D
Number of copies: 1
Write speed: 5540 KB/s
Temp folder: C:\Documents and Settings\Meraj\My Documents\Nero Recode\VIDEO_TS (54222245888 bytes free)
Direct burning: true
Target media: DVD R/RW, DVD DL, DVD-RAM
Shutdown when finished: false
Advanced Analysis: false
Compress Adaptive: true
16:30:31 File burn_dvdfiles.cpp, Line 238
Compile DVD: init
VMG Menus Vobs [1 vobus] 0.05MB -> 0.05MB [R 1.00]
Video: 0.05MB, extra: 0.00MB
Audio: 0 streams
Subpicture: 0 streams
VTS_01 Menus Vobs [192 vobus] 39.35MB -> 39.35MB [R 1.00]
Video: 36.98MB, extra: 2.37MB
Audio: 1 streams
0. 0. Dolby Digital 2-ch Unspecified 1.92MB [enabled]
Subpicture: 1 streams
0. 0. Unspecified 0.08MB [enabled]
VTS_01 Title Vobs [16377 vobus] 4176.69MB -> 4176.69MB [R 1.00]
Video: 3695.38MB, extra: 481.31MB
Audio: 1 streams
0. 0. Dolby Digital 5.1-ch Unspecified 449.33MB [enabled]
16:30:32 File burn_dvdfiles.cpp, Line 1244
Compile DVD: begin copy 1
16:31:15 File NeroRecorderBase.cpp, Line 517
Writing to disc: D
16:31:16 File NeroRecorderBase.cpp, Line 531
Free capacity on disc: 2286465 sectors (2298496)
16:31:17 File burn_dvdfiles.cpp, Line 548
Compile DVD: burning 2286465 sectors (2158757 required)
16:31:17 File burn_dvdfiles.cpp, Line 744
Compile DVD: adjust target size to 4465.75MB (4216.32MB obtained)
16:31:17 File burn_dvdfiles.cpp, Line 594
Compiling DVD Volume started
16:31:17 File burn_dvdfiles.cpp, Line 1150
Compile DVD: finished VMG Menus Vobs
VMG Menus Vobs:
Original 0.05MB -> Expected 0.05MB -> Output 0.05MB
Finished error 0.00MB
Ratio encoded = 0
Original encoded = 1
Slide encoded = 0
StillImage encoded = 0
Output extra size = 0.00MB
Source video size = 0.05MB
Pictures Modified [I 0] [P 0] [B 0]
16:31:17 File vob_record.cpp, Line 647
DirectBurn offset: VIDEO_TS.VOB 16
16:31:18 File vob_record.cpp, Line 647
DirectBurn offset: VTS_01_0.VOB 160
16:31:19 File burn_dvdfiles.cpp, Line 1150
Compile DVD: finished VTS_01 Menus Vobs
VTS_01 Menus Vobs:
Original 39.35MB -> Expected 39.35MB -> Output 39.35MB
Finished error -0.00MB
Ratio encoded = 1
Original encoded = 191
Slide encoded = 0
Output extra size = 2.26MB
Source video size = 37.09MB
Pictures Modified [I 0] [P 0] [B 4]
16:31:41 File NeroRecorder.cpp, Line 677
Burn failed (3)
----- Begin NeroAPI error log -----
EC81-K09K-18K0-M23X-400E-6M3A-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14/03/2007 12:43:16
NT-SPTI used
Nero API version: 7.11.10.0
Using interface version: 7.5.0.2
Installed in: C:\Program Files\Nero\Nero 7\Core\
Application: Ahead\Nero Recode
Internal Version: 7, 11, 10, 0
Recorder: <PIONEER DVD-RW DVR-216D>Version: 1.07 - HA 1 TA 0 - 7.11.10.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-216D atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3160815AS atapi Port 2 ID 0 DMA: On
DiskPeripheral : ST3500320AS atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-216D D: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 17
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.1.2009
NeroAPI
16:31:16 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
16:31:16 #2 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: -1 ( 0:00.-1, 0MB)
16:31:16 #3 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO
16:31:16 #4 Text 0 File DlgWaitCD.cpp, Line 2988
Recorder: PIONEER DVD-RW DVR-216D, Media type: DVD-R
Disc Manufacturer ID: <TTH02> <>
Disc Application Code: 64, Disc Physical Code: 193
16:31:16 #5 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
16:31:16 #6 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
16:31:17 #7 SPTI -1066 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x09142040: Len x648
16:31:17 #8 Text 0 File BurnAtOnceRecorder.cpp, Line 1028
Estimated filesystem size: 544
16:31:17 #9 Phase 36 File APIProgress.cpp, Line 282
Burn process started at 4x (5,540 KB/s)
16:31:17 #10 Text 0 File BurnAtOnceRecorder.cpp, Line 1727
Buffering files started
16:31:17 #11 Text 0 File BurnAtOnceRecorder.cpp, Line 1433
Buffering VIDEO_TS.VOB
16:31:17 #12 Text 0 File BurnAtOnceRecorder.cpp, Line 2626
Finished buffering file VIDEO_TS.VOB of size 57344 bytes (28 sectors)
16:31:17 #13 Text 0 File BurnAtOnceRecorder.cpp, Line 2693
Finished writing file VIDEO_TS.VOB of size 57344 bytes (28 sectors)
16:31:17 #14 Text 0 File BurnAtOnceRecorder.cpp, Line 2706
Buffering files finished successfully
16:31:17 #15 SPTI -1066 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x24
Sense Qual: 0x00
Buffer x091c1940: Len x648
16:31:17 #16 Text 0 File DVDR.cpp, Line 3262
Recording mode: Sequential Recording Mode for Multisession
16:31:17 #17 Text 0 File DVDR.cpp, Line 3416
Start write address at LBA 0
DVD high compatibility mode: No
16:31:17 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x24
Sense Qual: 0x00
Buffer x0b74e940: Len x648
16:31:17 #19 Text 0 File Cdrdrv.cpp, Line 10161
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0D 12 98 99 90 00 .@....R.........
03 54 54 48 30 32 00 00 - 04 00 00 00 00 00 00 00 .TTH02..........
05 88 80 00 00 00 02 00 - 06 09 0A 15 98 89 90 00 ................
07 88 80 00 00 00 00 00 - 08 07 14 0A 0E 09 04 00 ................
09 95 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................
0B 06 17 15 B8 99 85 00 - 0C B8 9A 32 03 20 32 00 ...........2..2.
0D 00 00 D0 00 00 00 00 - 0E 0B 21 39 35 2D 1F 00 ..........!95-..
0F 50 21 2D 15 98 B5 00 - 10 88 80 00 00 00 00 00 .P!-............
11 00 00 00 00 00 00 00 - 12 0B 2B 39 35 2D 1F 00 ..........+95-..
13 50 23 2F 19 97 B5 00 - 14 88 80 00 00 00 00 00 .P#/............
15 00 00 00 00 00 00 00 - 16 0A 3C 47 43 2C 27 00 ..........<GC,'.
17 80 21 2E 1A 78 B5 00 - 18 88 8C 00 0C 00 0C 00 ..!..x..........
19 00 00 00 00 00 00 00 - 1A 09 58 46 44 27 28 00 ..........XFD'(.
1B 70 21 2D 19 BA A5 00 - 1C 88 84 00 04 00 04 00 .p!-............
16:31:17 #20 Text 0 File BurnAtOnceRecorder.cpp, Line 689
Reserved fragment at 0. Length: 624
16:31:17 #21 Text 0 File BurnAtOnceRecorder.cpp, Line 1910
Reserved start fragment at 0
16:31:18 #22 Text 0 File BurnAtOnceRecorder.cpp, Line 689
Reserved fragment at 624. Length: 80
16:31:18 #23 Text 0 File BurnAtOnceRecorder.cpp, Line 1427
Writing VTS_01_0.VOB at sector 704
16:31:41 #24 SPTI -1 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1)
Sense Code: 0xA8
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 2F F0 00 00 20 00 00 00
Sense Area: 0x70 00 05 06 38 00 80 0E 24 08 10 40 A8 03
Buffer x08f99040: Len x10000
0x00 00 01 BA 44 00 FD 84 94 AB 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 72 40 2C 43 62 C9 5F A0 B7
0x29 F0 62 52 31 E0 10 10 8A 00 BC 9A 05 C2 77 48
16:31:41 #25 Text 0 File BurnAtOnceRecorder.cpp, Line 2236
Failed to write 128 sectors at 12176
16:31:41 #26 Phase 179 File APIProgress.cpp, Line 282
Writing file to disc failed
16:32:11 #27 SPTI -1169 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1169)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x07
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0E 00 00 00 00 04 07 00 80
Buffer x05769bc0: Len x20
16:32:16 #28 Text 0 File BurnAtOnceRecorder.cpp, Line 3710
Disc info:
Partitions: 2
#0: Start: 0, Size: 608
#1: Start: 624, Size: 64
16:32:16 #29 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
16:32:16 #30 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
16:32:16 #31 Text 0 File Cdrdrv.cpp, Line 11411
DriveLocker: UnLockVolume completed
16:32:22 #32 Phase 38 File APIProgress.cpp, Line 282
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
----- End NeroAPI error log -----
16:32:22 File burn_dvdfiles.cpp, Line 308
Compile DVD: exit
Old 10-01-2009, 5:26 PM   #2
1,959, Level: 10
Re: Pioneer dvd r error
is any 1 going to help me here
Powered by
 Latest popular product prices
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Toshiba DR20
2 prices from
 £148.09 Click to show/hide the offers
LG RHT497H 160GB
4 prices from
 £186.05 Click to show/hide the offers
Toshiba DVR20
5 prices from
 £181.54 Click to show/hide the offers
Panasonic DMR-EX773 160GB
6 prices from
 £209.03 Click to show/hide the offers
LG RHT498H 250GB
3 prices from
 £209.95 Click to show/hide the offers
Samsung DVD-HR734 160GB
1 price
 £216.99 Click to show/hide the offers
Panasonic DMR-EZ49VEGK
9 prices from
 £217.87 Click to show/hide the offers
 Updated February 11th at 10:30am. Prices include delivery.
