Holding out for the Sony RDR-HXD870
Old 06-05-2007, 10:55 PM   #1
9,620, Level: 23
Points: 9,620, Level: 23 Points: 9,620, Level: 23 Points: 9,620, Level: 23
Thanks: Gave 0, Got 6
Good thing, bad thing??
Capacity HDD: 160 GB
HDMI Output
HD 1080p upscaling
Digital TV Tuner
Advanced Electronic Program Guide (EPG)
DVD-R/DVD+R/DVD-RW/DVD+RW Recording (dual RW compatibility)
DVD-RAM/DVD-R/DVD+R/DVD-RW/DVD+RW Playback
High Picture Quality: HQ+ recording
Pause Live TV
DV Terminal (i.LINK): Program Dubbing/One Touch Dubbing/Advanced Program Dubbing
Anyone got any more inside information. Expected to be around the £245-£300 mark. Out mid June. Will this unit be compatible with my Sony 40V2500 which supports a video input of 1080i (not P). This one upscales to P (as above), will this cause problems with my TV ie. picture quality.
Old 07-05-2007, 8:12 AM   #2
15,639, Level: 30
Points: 15,639, Level: 30 Points: 15,639, Level: 30 Points: 15,639, Level: 30
Activity: 18.6%
Activity: 18.6% Activity: 18.6% Activity: 18.6%
Thanks: Gave 116, Got 438
Re: Holding out for the Sony RDR-HXD870
HDMI does not improve picture quality and you are already watching an upscaled picture, as all HD Ready TV's must upscale or otherwise you would have a tiny picture in the middle of the screen.
The more pleasing picture will likely come from outputting 576i for your own recorded programs and 576p when watching commercial film DVDs that are progressive. This means your TV does all the necessary picture processing in one go at the same time so is cleaner and introduces less artefacts. You can do this easily with component cables and HDMI is nothing more than a marketing gimmick. Just so you are not disappointed
So yes it will be compatible, just don't bother using the upscaling.
Regards
Phil
Old 07-05-2007, 9:07 PM   #3
9,620, Level: 23
I read somewhere that component leads are only for video signals, so what do I need to carry the audio (sound) from my source to the TV?
Old 07-05-2007, 9:43 PM   #4
2,269, Level: 11
Points: 2,269, Level: 11 Points: 2,269, Level: 11 Points: 2,269, Level: 11
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
I'm also holding out for it as it seems to tick every box. Will go with my new Samsung M87 which I also waited a long time for and am delighted with.
Sony will replace a 2 year old Liteon 5045 which was a piece of garbage. It never played DVD's reliably and now the tray won't even open, only good for recording from TV but the tuner is also substandard.
Will never buy Liteon again!
Sony must be multi-region and I'm relying on this forum to point me in the direction of a trustworthy retailer.
Old 08-05-2007, 2:18 AM   #5
marty2005's Avatar
80,106, Level: 69
Points: 80,106, Level: 69 Points: 80,106, Level: 69 Points: 80,106, Level: 69
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 5, Got 173
If u got a Samsung M87 then you might be better off waiting for the new Samsung SH853/855/857 digital dvd recorders since they have anynet that works with the new Samsung tv's.
Old 08-05-2007, 3:41 PM   #6
2,269, Level: 11
Activity: 1.7%
The Samsung recorders sound interesting. Can you point me in the direction of any specs. and when they are due in the stores?
Thanks.
Old 09-05-2007, 7:35 AM   #7
3,472, Level: 13
Points: 3,472, Level: 13 Points: 3,472, Level: 13 Points: 3,472, Level: 13
Thanks: Gave 10, Got 0
Originally Posted by PhilipL View Post
Regards
Phil
I am a bit confused now. When I first read the article below on Sunday I understood HDMI ensured a better picture now I am not so certain.
'......digital HDMI socket, an essential connection that delivers both video and audio in one convenient cable to your screen or surround-sound system. Crucially, it also offers the possibility of upscaling, where a standard-definition DVD picture is boosted (upscaled) to a clarity in theory approaching high definition, if viewed on an HD-ready screen.'
http://technology.timesonline.co.uk/...cle1747020.ece
Old 09-05-2007, 7:46 AM   #8
3,472, Level: 13
I have just got a Sony 32V2500 and was thinking of getting the Panosonic DMREX75. I see the new ones are due out shortly which will complete with the RDR-HXD870. Because of PhilipL's comments I think a cut price Panny might be almost as good as the newer models!
Old 09-05-2007, 2:24 PM   #9
marty2005's Avatar
80,106, Level: 69
Activity: 1.9%
The new Digital tuner Sh851/3/5/7 can be seen on the French Samsung website.
Should be in the UK soon. Komplett have the analogue tuner only models listed.
SH857
Old 09-05-2007, 10:33 PM   #10
9,620, Level: 23
Spoken to sales manager at Sony center yesterday he informs me that the 870 will upscale to 1080i on my TV as the DVD recorder supports video format upto and including 1080p (being the highest). Also mentioned that HDMI is the most superior connection between TV and HDMI device. Component leads are Analogue at the end of the day. Only good if no HDMI input/output available.
Appearence wise this unit looks so sweet, a bit like the sky HD box shiny and black. If you're ever passing a sony center get them to show you the picture and spec from their dealer brochure. Some play ignorant and say "Oh we don't know much about it or when it's out". play them at their own game that's what I say.
Old 10-05-2007, 3:37 AM   #11
marty2005's Avatar
80,106, Level: 69
Activity: 1.9%
Wot I like about the Samsungs is that u can copy mp3/divx/jpgs to hard disk and back to dvd.
Still no cd-text and dot-matrix display on any dvd recorders.
No card readers either except pana but that is for jpegs only and I think only 1 way copy.
anap (07-07-2007)
Old 10-05-2007, 5:42 AM   #12
3,472, Level: 13
It seems the Panny copies jpgs to the HDD via the SD card.
Can either the Panny or the Sony copy MP3 and/or MPEG to the HDD via disc or SD card?
Old 10-05-2007, 7:49 AM   #13
DolbyDan's Avatar
6,392, Level: 19
Points: 6,392, Level: 19 Points: 6,392, Level: 19 Points: 6,392, Level: 19
Thanks: Gave 30, Got 66
Regards
Phil
Yeah except REAL hd players then HDMI is a must for HD sound and a plus for HD picture, hate it when they say its a gimmick
Old 10-05-2007, 11:40 AM   #14
6,751, Level: 19
Points: 6,751, Level: 19 Points: 6,751, Level: 19 Points: 6,751, Level: 19
Thanks: Gave 36, Got 79
Also cheaper, neater, smaller and less susceptible to cable quality that component cables, plus they carry sound. Some good gimmicks right there.
Old 10-05-2007, 12:30 PM   #15
2,627, Level: 11
Points: 2,627, Level: 11 Points: 2,627, Level: 11 Points: 2,627, Level: 11
Thanks: Gave 3, Got 10
Try this link regarding prices on the HXD870: http://www.cheapelectricals.co.uk/ac...drhxd807b.html
Old 13-05-2007, 7:50 AM   #16
9,620, Level: 23
Brief review/article in June's Home cinema Choice. Looks like this and other models in range will be quite popular
Old 14-05-2007, 6:22 PM   #17
Knyght_byte's Avatar
22,868, Level: 36
Points: 22,868, Level: 36 Points: 22,868, Level: 36 Points: 22,868, Level: 36
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 96, Got 655
HDMI isnt a must for HD sound....it can be carried over 6/8 channel analogue...(and to stem the digi/analogue audio debate, when that digital signal gets to your AV amp, it still gets turned in to analogue to be amplified, its quite possible the HD player will do the DAC work better than the Amp will so analogue connection between the two will prove superior....but that argument all comes down to the actual equipment, not the connection type)
also component can carry HD picture, although not many TV's will take 1080 by component...but a lot of large screen projection systems do....lets face it, you spend the money, get the big screen, forget 50in
Old 20-05-2007, 11:52 PM   #18
9,620, Level: 23
1 shop on Tottenham Court Road (London) already has it. I wonder if it's UK spec and not an import.
Old 22-05-2007, 11:12 PM   #19
9,620, Level: 23
It was a hoax. Stupid dealer trying to tease me.
Old 29-05-2007, 12:43 PM   #20
2,643, Level: 11
Points: 2,643, Level: 11 Points: 2,643, Level: 11 Points: 2,643, Level: 11
Thanks: Gave 23, Got 38
My HXD860 displays CD Text although it only appears to display the CD name, not individual track names (not sure if that is a problem with the HXD860 or the way I have burnt the CDs).
Old 29-05-2007, 3:53 PM   #21
6,158, Level: 18
Points: 6,158, Level: 18 Points: 6,158, Level: 18 Points: 6,158, Level: 18
Thanks: Gave 1, Got 0
Anybody know if the 870 will upscale SKY signals to HDMI when connected to the 870 by the scart input? also does it only have 1 RGB scart?
Martin.
Old 29-05-2007, 10:50 PM   #22
9,620, Level: 23
Correct me if I'm wrong but I thought you need either a DVI or HDMI connection for upscaling with a compatible device, I don't think you can upscale from a regular Sky box through a Dvd recorder with HDMI output and especially not with a scart connection.
Old 30-05-2007, 7:51 AM   #23
6,751, Level: 19
Martin.
Yes it will, same as the 860 already does.
Happy to correct you . 860 and 870 can be set to output an upscaled resolution via HDMI or Component (720p, 1080i, 1080p on the 870) everything that they display is upscaled to that res, including anything that comes in via the scart socket such as SKY.
But, your HDTV upscales all inputs to the panel res any way, it has to. So getting the 860/870 to do the scaling will usually result in 2 scaling steps (if the TV is not full 1920*1080p res).
Old 30-05-2007, 8:19 AM   #24
6,158, Level: 18
Are both the Scart sockets RGB? as it would be useful if it could pass through RGB from SKY to my TV when it is switched off.
Martin.
Old 30-05-2007, 11:15 AM   #25
6,751, Level: 19
Martin.
860 will take in and pass out RGB. Of course, it won't pass an upscaled or progressive pic out through SCART.
Old 01-06-2007, 11:23 PM   #26
4,794, Level: 16
Points: 4,794, Level: 16 Points: 4,794, Level: 16 Points: 4,794, Level: 16
Thanks: Gave 4, Got 2
Hi everybody
Looking to get a DVD Recorder and I want to get a 1080p version to go with my 1080p LCD.
I don't know much about DVD Recorders but the Sony RDR-HXD870 looks pretty good. Was thinking of going for the Panasonic DMR-EX77 but it doesn have the series recording stuff like the Sony.
Unfortunately I can't get Freeview in my area! Can I plug my Sky box into the DVD Recorder so I can record stuff. Im not sure if I can. I only have the box standard Sky connected by Scart.
Any help would be a bonus. Thanks
Old 02-06-2007, 6:32 AM   #27
AndrewH13's Avatar
8,246, Level: 21
Points: 8,246, Level: 21 Points: 8,246, Level: 21 Points: 8,246, Level: 21
Activity: 29.9%
Activity: 29.9% Activity: 29.9% Activity: 29.9%
Thanks: Gave 181, Got 118
Even if the TV is 1080P, I suspect 95% of people wont have 1:1 pixel matching switched on, so scaling will still take place?
Old 02-06-2007, 1:37 PM   #28
marty2005's Avatar
80,106, Level: 69
Activity: 1.9%
Forgot what I was gonna say.
Old 03-06-2007, 1:20 PM   #29
4,224, Level: 15
Points: 4,224, Level: 15 Points: 4,224, Level: 15 Points: 4,224, Level: 15
Thanks: Gave 32, Got 18
When did Sony start using GuidePlus in the "D" models? I notice the 870 is listed as using GuidePlus here:
http://www.europe.guideplus.com/En/o...ce/models.html
Does the 860 use GuidePlus? Personally I hate GuidePlus and hope it can be disabled in preference to the Freeview EPG. The Pioneers can use GuidePlus and it makes it quite noisey at night while it downloads.
Old 04-06-2007, 9:32 AM   #30
9,620, Level: 23
Apart from Play.com does anyone know when the mainstream shops like Currys/John Lewis/Comet and more importantly Sony Shops will be selling this and other new models in the range. If you look on the Sony website they still have the current (previous) models listed.
Powered by
 Latest popular product prices
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Toshiba DR20
2 prices from
 £148.09 Click to show/hide the offers
LG RHT497H 160GB
4 prices from
 £186.05 Click to show/hide the offers
Toshiba DVR20
5 prices from
 £181.54 Click to show/hide the offers
Panasonic DMR-EX773 160GB
6 prices from
 £209.03 Click to show/hide the offers
LG RHT498H 250GB
3 prices from
 £209.95 Click to show/hide the offers
Samsung DVD-HR734 160GB
1 price
 £216.99 Click to show/hide the offers
Panasonic DMR-EZ49VEGK
9 prices from
 £217.87 Click to show/hide the offers
 Updated February 11th at 8:30am. Prices include delivery.
