Panasonic DRM EX85 reverts to TV channel from AV when selecting from the Guide
Old 16-11-2006, 7:23 PM   #1
Adrian01
Posts: n/a
I have just bought a Panasonic DRM EX85 and am using it with my big old Sony Trinitron TV. The TV has 2 scarts and I have connected the DRM EX85 to the bottom scart (AV1). It all works fine BUT when I select a programme to watch from the Guide on the DRM EX85 I see it for a split second and then my TV switches from AV1 back to the last selected channel on the TV. I can get back on to AV1 by hitting the AV button on the Panasonic remote control but I'd obviously rather be able to go straight to the programme I selected. I have plugged to Panasonic into a little portable Bush TV and don't get the same problem, so it looks like the problem lies with my Sony TV. Any ideas?
Old 16-11-2006, 7:53 PM   #2
JayCee's Avatar
30,398, Level: 42
Points: 30,398, Level: 42 Points: 30,398, Level: 42 Points: 30,398, Level: 42
Activity: 37.8%
Activity: 37.8% Activity: 37.8% Activity: 37.8%
Thanks: Gave 168, Got 1,190
Re: Panasonic DRM EX85 reverts to TV channel from AV when selecting from the Guide
You should be pressing the AV input button on the Sony TV remote...not the Panasonic remote.
Old 16-11-2006, 8:40 PM   #3
Adrian01
Posts: n/a
Thanks JayCee. I have programmed (put the Sony code) into the Panasonic remote so it can select AV1, 2 and 3, change the channels and adjust the volume on the TV. It just saves using two remotes.
I need to find a way of keeping the TV on AV1 when I select a programme from the freeview guide on the Panasonic. Thanks for your suggestion anyway.
Old 17-11-2006, 4:02 PM   #4
KMO KMO is offline
6,228, Level: 18
Points: 6,228, Level: 18 Points: 6,228, Level: 18 Points: 6,228, Level: 18
Thanks: Gave 2, Got 57
This has come up before. Try changing the video output format to "RGB 1" instead of "RGB 2" (or vice versa).
Old 17-11-2006, 4:10 PM   #5
JayCee's Avatar
30,398, Level: 42
Activity: 37.8%
I knew those symptoms rang a bell, just couldn't think where I read it.
Old 17-11-2006, 6:10 PM   #6
Adrian01
Posts: n/a
KMO, it works. Can't thank you enough. I called the Panasonic helpline yesterday and they just said it was a Sony issue and offered no more advice. I am very grateful indeed. What exactly is RGB output? Will changing it change anything else?
Old 17-11-2006, 6:50 PM   #7
4,542, Level: 15
Points: 4,542, Level: 15 Points: 4,542, Level: 15 Points: 4,542, Level: 15
Thanks: Gave 0, Got 3
I've noticed this too, I'll check my settings, thanks.
Old 17-11-2006, 10:32 PM   #8
Senior Moderator
80,862, Level: 69
Points: 80,862, Level: 69 Points: 80,862, Level: 69 Points: 80,862, Level: 69
Activity: 39.5%
Activity: 39.5% Activity: 39.5% Activity: 39.5%
Thanks: Gave 1,220, Got 3,010
The question is how or why did you manage to get it set it to RGB 2 in the first place ... because that is not the default?
Old 17-11-2006, 11:56 PM   #9
4,247, Level: 15
Points: 4,247, Level: 15 Points: 4,247, Level: 15 Points: 4,247, Level: 15
Thanks: Gave 0, Got 7
Gav, it is RGB2 as default!
Old 18-11-2006, 1:13 AM   #10
Senior Moderator
80,862, Level: 69
Activity: 39.5%
Thats a surprise to me! -
In which case - Apologies for the pointless post
Old 18-11-2006, 2:03 AM   #11
4,247, Level: 15
no worries
Old 18-11-2006, 3:21 PM   #12
KMO KMO is offline
6,228, Level: 18
It is a bug in the TV. There's a signal on the SCART that says the picture is RGB rather than composite (do a net search if you don't know what that means). For some reason I'm not sure about, the Panasonic defaults to "RGB 2" mode which outputs composite for normal TV, but RGB for menus.
The TV has a bug in that it thinks when it sees the RGB signal deactivated the device has gone away. That's wrong - there's a separate signal which indicates whether a device is active or not.
By setting it to RGB 1 mode, it's now outputting RGB all the time. That will be better quality, and it avoids the TV bug. I don't know why it's not the default.
Powered by
 Latest popular product prices
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Toshiba DR20
2 prices from
 £148.09 Click to show/hide the offers
LG RHT497H 160GB
4 prices from
 £186.05 Click to show/hide the offers
Toshiba DVR20
5 prices from
 £181.54 Click to show/hide the offers
Panasonic DMR-EX773 160GB
6 prices from
 £209.03 Click to show/hide the offers
LG RHT498H 250GB
3 prices from
 £209.95 Click to show/hide the offers
Samsung DVD-HR734 160GB
1 price
 £216.99 Click to show/hide the offers
Panasonic DMR-EZ49VEGK
8 prices from
 £217.87 Click to show/hide the offers
 Updated February 14th at 2:30am. Prices include delivery.
