Originally Posted by Gez_pw6 Hi there,
Probably a stupid question but is it possible to record sky programs to a HDD without using sky+?
If yes could these recordings be transfered to DVD at a later date?
If you can record sky what equipment would I need? |
Yes it is possible... but bear in mind that some channels and / or some programmes delivered by Sky are copy protected and will not copy.
Find a dedicated sky forum and check out what you can and cant copy.
A Hard Disk equipped DVDR would be required... Yes you could transfer to DVD.
