Originally Posted by *Joanne* What am I doing wrong is it best to try another brand of discs or could it be the dvd recorder that has the fault.
Thanks Joanne |
Hi Joanne - I have the DVD-R125 model. I think it could be the brand of disc you are using.
In my manual it says it only confirm conpatibility with certain makes of disc - other should work - and of certain speeds.
DVD-Ram Maxwell Fujifilm TDK Panasonic (3x speeds) - I use Panasonic.
DVD-RW TDK Maxwell Optodisc Radius Verbatim (2x speeds) - I use Philips which seem to work OK
DVD-R TDK Beall That's Maxwell Panasonic - I use (4x speeds) - I use Logik (from PC World) and they work OK although I had one giving errors.
Hope that helps, Dave C.
