Originally Posted by trimjf Thank you fir response. Just to be absolutely clear...you're saying you have to:
- Go to guide
- Find show
- Note down times and channel
- Get out of guide
- Go to menu
- Select timer...etc etc
Which Is very convoluted compared to:
- Go to guide
- Find show and select to record
- Modify to be weekly
which is what I could do on my old Sony. Is the latter not possible? If not, this appears to be a significant usability oversight!
Jon |
It is important to be clear about a few things here.
A weekly timer is not the same as a series timer.
A weekly timer is a manually driven timer, Series recording is controlled by EPG data.
A weekly timer would go on for ever. A series timer only as long as the series is broadcast.
Additionally a Series timer is recorded no matter when the programme is broadcast, whereas a weekly timer will be exactly that.
Series timer options are dependent on guide data supplied by the broadcasters. I don't think this is anything to do with the machine.
If they do not provide Series record options then there is no workaround.
I don't know why these anomalies occur ...or if cleaning out all the EPG data and refreshing it would change this - I strongly suspect not.
For reasons best known to themselves broadcasters, for some programmes, do not provide a series record option... and sometimes they will do it for a programme one week and not for another.
For any timer already programmed you can press 'Prog Check' to access it and change any parameters you wish ... but not all parameters will be accessible.... especially where recording is dependent on EPG Data, as is the case with Series recording.
