PiDATA BD-R 50GB DL 6X
On occasion, I use a 50GB disc in my DMR-BW780.
Some media just wiil not format in my machine, or do not burn correctly, and end up as coasters.
Not with PiDATA. They format with no problems, and have so far created perfect recordings.
They are made in Taiwan by "Ritek", and cost £33.95 for 10 on Amazon.
They also work flawlessly on my Samsung SE-506AB/TSB Blu-ray writer I have connected to my PC.
However, I notice you can't clone the discs made on the BW780, although this is no fault of these discs I must add.
Would wholeheartedly recommend.
Rob
