Originally Posted by Gavtech DVD-R recording is always restricted to 4:3 on this machine.
I presume you must be high speed copying to get this result.
I dare say if you real-time copy it will display in the correct ratio. |
Thanks for the reply Gavtech.
No I recorded real-time from a SKY+ box.
I haven't used the recorder for ages and then I mostly used RAM discs.
I'm pretty sure though that I previousy did record to DVD-R without this issue.
I have only just up-graded the recorder's OS to take X16 discs and this is the first time I have used it since to make a DVD-R recording.
I subsequently checked to see if RAM discs were OK and they were.
Panasonic tech team referred me to a page ( 16) in the manual showing that 16.9 is only recorded on RAM and said that it was the DVD-R discs themselves that didn't allow recording to the WS format.
The DVD-R recording can be viewed OK by using the TV's own aspect ratio options, but if the recording was played back via HDMI on another machine I guess it would be stuck on 4.3 stretched vertically?
I just wondered if this is a general problem with DVD-R format or just peculiar to Panasonic, and if just Panasonic, why.
Thanks, Thomas
