What is the original file ? Is it from a camcorder, or something else?
( I guess you mean BD-RE, as per the title, not BD-RW, as there is no such thing as the latter.)
Some BD recordings from TV will only play on the machine - or the same make of machine ( and a few others ) they are burnt on, such as the new Panasonic BD recorder. Files from camcorders are usually fine though, and should play on any BD player or PS3.
If the original file is downloaded, then that's another matter !
You could try burning to a normal BD-R disc, and finalise that.
