Originally Posted by cool_breeze Apologies if I got it wrong. Sorry, I'm not really a tech kind of person.
Sorry Gavtech too I really don't understand what that means. lol. Could you explain that please lol |
basically , what you have there is a dvd
PLAYER ( the
dvp part of the model number ) , and its not a recorder
because it is not a recorder it has no rf input , no rf output and no built in tuner or anything
what you decided was an rf socket is in fact a coaxial output ( phono socket ) and is used to connect to a separate surround sound audio system to get 5.1 surround sound , instead of the more usual stereo sound , so its probably a sound output socket , and not what you said
so several of your presumptions are wrong , the first one being that you thought you had a recorder , which you havent , you have a dvd player
so you can play disks , but cannot record on disks , and cannot connect to your sky box either
if you want a dvd recorder , buy a sony hxd890 or 995 or similar
