Originally Posted by bigmin
I wonder, are you then able to explain the differences between “Video Format” and “ VR Format”? You mentioned that they were related to quality mode settings, but the user manual seems to allow all recording modes in both recording formats. |
They do. My point in mentioning the quality modes was simply to show that if variable quality modes are available - which they are with
every recording, then that indicates that every recording is going through the encoder.
The only time the encoder is not invoked is when high speed copying from one medium to another.
Originally Posted by bigmin I realise that an HDD recording must be in “Video Format”, i.e. programme stream, if high speed copying will be needed afterwards (other than to RAM). The manual recommends using “VR Format” if high speed copying is not expected. So, something is not being properly explained by Panasonic.
Thank you, again, for all the help you provide to us all.
Regards
bigmin |
When DVD's were first conceived they were not envisioned as recording media.... but naturally much technological development occurred and gradually recordable types emerged and over time were improved upon.
They were also developed before digital TV transmission emerged, which has different technical requirements and so, unsurprisingly the systems are not compatible.
Each DVD development has had to find a way of fitting into the existing infrastructure. Consumers don't want to have to buy a new machine for every incremental development and are only prepared to do so when there is a quantum leap.. [e.g. Bluray]
That has left us with the kind of mess we are in now with the main five different DVD format types and their associated recording mode forms.
The original universal commercial DVD is based upon the DVD Video format.
It is the one type that can reasonably expected to play anywhere - given that one expects a Commercial DVD to play anywhere.
But the way this format is structured does not lend itself to editing very well ...which was one of the driving forces of the development of the VR format.
So to get back to your original question, you will not see any differences in terms of picture quality. These modes have no impact on that.
They impact on editing accuracy, ease of transferability, and compatibility.
For general best use with the mainstream Japanese 'origin' recorders - Use the default mode settings [ for both quality and recording mode type ] , High speed copy when archiving to disc.. to '-' type discs only [ Reason: Aspect limitation with '+' types ]
