DVD recorder doesn't connect to D8 Camcorder via composite cable
Old 05-07-2009, 1:54 PM   #1
kurrajong
Posts: n/a
Please help. I try to record a family video to a DVD recorder from an old D8 Camcorder via composite cable. But the DVD recorder keep saying not connected. Anyone knows what's wrong. It's no problem to connect and record from the new camcorder via firewire cable. But this old camcorder doesn't come with firewire port.
Many thanks,
Old 05-07-2009, 3:25 PM   #2
Senior Moderator
80,763, Level: 69
Points: 80,763, Level: 69 Points: 80,763, Level: 69 Points: 80,763, Level: 69
Activity: 41.2%
Activity: 41.2% Activity: 41.2% Activity: 41.2%
Thanks: Gave 1,217, Got 3,008
Re: DVD recorder doesn't connect to D8 Camcorder via composite cable
What type/ model of DVD recorder is it?
kurrajong (06-07-2009)
Old 06-07-2009, 1:27 PM   #3
kurrajong
Posts: n/a
Sony RDR-HXD870 DVD Recorder
Thanks,
Old 06-07-2009, 2:10 PM   #4
Senior Moderator
80,763, Level: 69
Activity: 41.2%
I'm intrigued which method of transfer here you may be trying to use here, because I don't think the DVDR is capable of generating that message when using that input.
When using the composite input , do not attempt to use any special camcorder system commands on the DVDR as they will only apply when using the DV input... which would account for the message.
It should work if you simply connect the camcorder, use the DVDR input select button to select the appropriate input.
Press play on the camcorder and press record on the DVDR - Monitor the output via TV.
Good luck.
Old 07-07-2009, 12:36 PM   #5
kurrajong
Posts: n/a
I can play the video via composite cable connection. The problem is I can't record to DVD via composite cable. Any solution? It's an old Digital 8 camcorder
Old 07-07-2009, 12:56 PM   #6
12,393, Level: 26
Points: 12,393, Level: 26 Points: 12,393, Level: 26 Points: 12,393, Level: 26
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 25, Got 209
When you say you can play via a composite connection do you mean connected directly to tv or thru the dvd recorder?
Also is your camcorder a uk model playing back pal video or is it imported and records/plays ntsc video?
If its ntsc there may be a setting to change on the sony.
Old 07-07-2009, 1:20 PM   #7
1,586, Level: 9
Points: 1,586, Level: 9 Points: 1,586, Level: 9 Points: 1,586, Level: 9
Thanks: Gave 0, Got 13
kurrajong, you need to respond to gavtech's suggestions, otherwise this will end up as a tedious guessing game (which no one will want to play).
Gavtech (07-07-2009)
Old 07-07-2009, 1:31 PM   #8
Senior Moderator
80,763, Level: 69
Activity: 41.2%
It is probably better to record to the hard disc first rather than direct to DVD ... but please address the points in Post 4 as Ian urges.
Old 07-07-2009, 2:13 PM   #9
4,293, Level: 15
Points: 4,293, Level: 15 Points: 4,293, Level: 15 Points: 4,293, Level: 15
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 21, Got 265
Is it possible that he is just connecting to the composite outputs on the rear of the machine rather than the composite inputs on the front of the machine ?
Old 07-07-2009, 3:06 PM   #10
Senior Moderator
80,763, Level: 69
Activity: 41.2%
Good suggestion. Quite possible...but we'll never know until we get direct feedback.
Kurrajong?
Powered by
 Latest popular product prices
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Toshiba DR20
2 prices from
 £148.09 Click to show/hide the offers
LG RHT497H 160GB
4 prices from
 £186.05 Click to show/hide the offers
Toshiba DVR20
5 prices from
 £181.54 Click to show/hide the offers
Panasonic DMR-EX773 160GB
6 prices from
 £209.03 Click to show/hide the offers
LG RHT498H 250GB
3 prices from
 £209.95 Click to show/hide the offers
Samsung DVD-HR734 160GB
1 price
 £216.99 Click to show/hide the offers
Panasonic DMR-EZ49VEGK
9 prices from
 £217.87 Click to show/hide the offers
 Updated February 11th at 11:30pm. Prices include delivery.
