If your failures are at start of recording, it is worth putting a title on the disc before you start. If the media will take a title they will normally work for a timer recording, as the failure is in the first 30 seconds when they try to start writing.
I am afraid the above just does not work with the unpredictability of Ritek and the Panny machines.
I have had Ritek discs even after that test that will record for about 20 minutes or so and then the machine sort of stops recording but imediately starts a new menu. Both menues play when finished but of course there are several second lost while the machine was faffing about with the Ritek disc. This is not good news if you are recording a musical number.
Ritek are a blessed nightmare on some Pannies. They are just not worth the hassle while there are far far better compatible DVD-R media out there. They may record ok but they also have a habit of stuttering on other machines. I have had enough of them. As i said. Just not worth the hassle.
