Originally Posted by emjga Folks
I am looking for a Replacement for a very dead Panasonic DMR-EX85
Only real Requirements are:
1. Free View Tuner
2. Program guide would be able to pick up a Series of Programs
Like Corrination Street (for the misses)
3. Have a good size Hdd
Optional Requirement:
1. Dual Tuner
2. Been able to Archive programs to my PC without having to burn them to a DVD first and then edit them on the PC
Yes I know all most imposable to do, maybe Blue Ray is the answer but media costs a arm and a leg.
Unit does not have to be a Panasoinc could be any leading brand.
If it makes any difference TV is :Panasoinc TH-37PE50B
Any suggestions would be most welcome.
Matthew |
Matthew
An EX78 or EX79 would be the machine for you [ or EX88 / 89 if you want a bigger hard disc ]
Your optional requirements are no-go's and likely will always be.
Getting material
off a machine will stay restricted to using discs as the transfer medium.
There are no dual tuner units.
The upcoming Dual Tuner Bluray recorders have Freesat tuners not Freeview
