Pioneer 868AVi
Old 07-10-2003, 4:52 PM   #1
337GUS's Avatar
5,848, Level: 18
Points: 5,848, Level: 18 Points: 5,848, Level: 18 Points: 5,848, Level: 18
Thanks: Gave 0, Got 13
Pioneer 868AVi
Just found this on Avland, thought some of you may be interested.
http://www.avland.co.uk/pioneer/dv868avi/index.htm
Looks like I will probably replace my DV88P with this.
Regards
Gus
Old 07-10-2003, 5:15 PM   #2
9,943, Level: 23
Points: 9,943, Level: 23 Points: 9,943, Level: 23 Points: 9,943, Level: 23
Thanks: Gave 0, Got 5
looks nice
Old 07-10-2003, 5:47 PM   #3
6,557, Level: 19
Points: 6,557, Level: 19 Points: 6,557, Level: 19 Points: 6,557, Level: 19
Thanks: Gave 10, Got 9
Does that look like a gold finish? or is it silver?
If its silver then I want!
7MAT
Old 07-10-2003, 5:49 PM   #4
6,557, Level: 19
Techtronics also has them listed @ £789.00 inc multi-mod!
http://www.techtronics.com/uk/shop/5...vd-player.html
7MAT
Old 08-10-2003, 7:44 AM   #5
krl25sc
Posts: n/a
For some reason at the Heathrow hi-fi show, the Pioneer reps were talking about a retail price of £1200 on the 868 - so that price is quite a relief - the 868 at the show was silver and I thought the picture via HDMI to an HDE 504 50" display was really quite outstanding - hence the imminent appearance of my Samsung 935 (and Panasonic 6 pasma) on the classified forum! Interested to hear what others thought who saw this demonstration.
Old 08-10-2003, 8:00 AM   #6
wilber's Avatar
14,876, Level: 29
Points: 14,876, Level: 29 Points: 14,876, Level: 29 Points: 14,876, Level: 29
Thanks: Gave 5, Got 30
668 also listed on avland:
http://www.avland.co.uk/pioneer/dv668av/index.htm
Old 08-10-2003, 8:10 AM   #7
Location: SBC (Swedish Born Chinese)/lived in UK since 96, Colchester since 02
8,490, Level: 22
Points: 8,490, Level: 22 Points: 8,490, Level: 22 Points: 8,490, Level: 22
Thanks: Gave 21, Got 30
I wrote about it already in 9th September in my summary thread from the IFA Berlin. But no one took notice?
It is in silver.
Wasabi
Old 08-10-2003, 9:26 AM   #8
warboy
Posts: n/a
I thought it was going to have a DVI out? Shame
Old 08-10-2003, 9:40 AM   #9
krl25sc
Posts: n/a
As I understand it, you can use an HDMI/DVI adapter at the TV end if you only have a DVI input (although you obviously won't be able to get the audio feed through DVI) - this is actually not so bad as the HDMI cable I saw is quite a bit thinner than a DVI cable.
Old 08-10-2003, 9:44 AM   #10
warboy
Posts: n/a
Does that mean I could use the HDMI, with adaptor, to plug and play straight into the DVI input on my TW100 projector?
Old 08-10-2003, 5:45 PM   #11
6,557, Level: 19
Planning on ordering one of these beauties.
Where can I buy a HDMI to DVI adaptor?
7MAT
Old 08-10-2003, 7:43 PM   #12
Dutch's Avatar
8,434, Level: 21
Points: 8,434, Level: 21 Points: 8,434, Level: 21 Points: 8,434, Level: 21
Thanks: Gave 233, Got 115
You need to take care with HDMI and DVI. HDMI is encryted with HDCP, so your DVI input would need to be HDCP compliant. 7MAT - HDMI to DVI adapters don't appear to have been released yet.
Steve
Old 09-10-2003, 2:56 PM   #13
7,989, Level: 21
Points: 7,989, Level: 21 Points: 7,989, Level: 21 Points: 7,989, Level: 21
Using the 868 with the PDA5002 will be a bit limited via DVI, the issue is the DVI input on that boards is limited to 480p Video input.
Old 09-10-2003, 5:48 PM   #14
Dutch's Avatar
8,434, Level: 21
Hi Tony,
I don't think it would take even a 480p signal if it is HDCP encryted (more than likely, I think).
Steve
Old 09-10-2003, 5:52 PM   #15
warboy
Posts: n/a
this is perhaps a new (or old) thread... i get confused by DVI etc
I am planning to get a marantz 8400, which has DVI out, will I be able to just plug it into the back of my TW100 and enjoy digital to digital cinematic heaven
Old 09-10-2003, 6:29 PM   #16
7,989, Level: 21
Steve, HDMI will only be HDCP if the source is HDCP encrypted to begin with, ie it has HDCP flags on the DVD. If this is not the case, then 480p will be OK (theoretically) with the PDA5002 via DVI & cable.
Warboy, yes you will . What you will need to look into is future HDCP content (copyprotected). Basically to display this type of conent everything from source to display must support HDCP. So that is the DVD player, your amp and the projector in your case.
The problems we are refering to are with respect to the Pioneer 433MXE & its PDA5002 board.
Old 09-10-2003, 6:53 PM   #17
Dutch's Avatar
8,434, Level: 21
Hi Tony,
I thought it was the player that added the HDCP signal, as happens with the Samsung HD931 in the US.
Steve
Old 09-10-2003, 9:02 PM   #18
7,989, Level: 21
Hi Steve.
My understanding is the 'handshake' process is initiated with other components only if flags are on the source to begin with. Hence its backwards compatability with DVI (both HDCP and Non-HDCP).
Tony
Old 10-10-2003, 8:51 AM   #19
warboy
Posts: n/a
is HDCP going to be addded to al DVD's - R1 & R2? If so, when is this likely to take place?
Old 10-10-2003, 11:02 AM   #20
5,800, Level: 18
Points: 5,800, Level: 18 Points: 5,800, Level: 18 Points: 5,800, Level: 18
Thanks: Gave 0, Got 107
This is mistaken - if the DVD is CSS protected so that Macrovision is enabled on the analogue video outputs, then HDCP coding will be applied to a DVI or HDMI digital video output. In practice this would mean just about all regular DVDs would switch on HDCP.
If your display is not HDCP compliant these digital video outputs are essentially unusable!
John Dawson (Arcam)
Old 10-10-2003, 12:31 PM   #21
7,989, Level: 21
John, Im not sure if I should thank you for that clarifcation or not !
Old 10-10-2003, 4:08 PM   #22
warboy
Posts: n/a
me neither - does that mean the DVI out is redundant, save for watching back catalogue discs on a player with DVI (not HDMI) out???
Old 10-10-2003, 4:43 PM   #23
warboy
Posts: n/a
Old 10-10-2003, 5:17 PM   #24
7,989, Level: 21
Basically means that if you buy one of these players (in fact I imagine any of the other pending branded players - ie Denon A11) with a HDCP DVI/HDMI output, then in order to use these outputs your display will have to support HDCP, this will be the case with pretty much *all DVD's*.
Old 10-10-2003, 7:54 PM   #25
9,943, Level: 23
what the ell is hdcp
Old 10-10-2003, 8:01 PM   #26
7,989, Level: 21
Extract from AVSFORUM:-
HDCP stands for High-bandwidth Digital Content Protection. It is an encryption standard being pushed by the movie and television industries. It is meant to protect hi-definition and other digital content from being downloaded onto a storage device before it reaches your display. This is to protect the material from unauthorized reproduction.
Old 10-10-2003, 8:05 PM   #27
9,943, Level: 23
how do we know if a display can use hdcp then.
say the sony hs3
Old 10-10-2003, 8:22 PM   #28
Cool-hand's Avatar
8,643, Level: 22
Points: 8,643, Level: 22 Points: 8,643, Level: 22 Points: 8,643, Level: 22
Thanks: Gave 24, Got 74
Yeah, or the HS20 or Infocus 5700? The respective dvd makers websites are not clear if at all on this.
S.
Old 11-10-2003, 9:13 AM   #29
7,989, Level: 21
Your display will state whether its HDCP compliant, it will be a key feature. Alternativly, as with some plasma's, youll have the opportunity to purchase a DVI/HDCP input board. A key thing point to remember is to play HDCP content everything within the chain from source to panel must support HDCP.
Old 11-10-2003, 9:18 AM   #30
wendt
Posts: n/a
Sony HS3 & HS20 will both have HDMI outputs and as I'm aware HDMI must always incorporate HDCP.
About DVI and HDCP.
If you look at the specifications on for example InFocus 5700 you can read "DVI/HDCP".
I'm pretty sure that all DVI products that incorporate HDCP writes this in the specifications.
So if you see DVI output but not HDCP next to it, it will probably not handle HDCP.
/Wendt
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
Samsung DVD-D530
3 prices from
 £35.90 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
8 prices from
 £89.95 Click to show/hide the offers
 Updated February 10th at 6:30am. Prices include delivery.
