Panasonic DMP-BD35 Region B problems
Old 17-02-2009, 6:47 PM   #1
4,944, Level: 16
Points: 4,944, Level: 16 Points: 4,944, Level: 16 Points: 4,944, Level: 16
Thanks: Gave 1, Got 5
hi just brought a panny dmp bd35 region b
from amazon (from one of their selling partners)
but every blu ray i put in, it keeps coming
up with copyright violation..blu rays i have are either region b
or region a (but region free)
ie troy, matrix trilogy, hulk 2003, superman returns, 300, superman
shawshank redemption
can anyone help its driving me mad it says region b on the box
Old 17-02-2009, 6:56 PM   #2
Eminent Member
kingfats's Avatar
106,226, Level: 79
Points: 106,226, Level: 79 Points: 106,226, Level: 79 Points: 106,226, Level: 79
Thanks: Gave 1,193, Got 7,647
Re: Panasonic DMP-BD35 Region B problems
Even the region free BD's won't play? they should play on any player.
Have you tried DVD.
Old 17-02-2009, 7:07 PM   #3
4,944, Level: 16
normal dvds work fine but none of my blu rays work
they use to work fine on my sony s300 before i sold
that machine, it just keep coming up with
copyright violation
really winding me up now
Old 17-02-2009, 7:19 PM   #4
Eminent Member
kingfats's Avatar
106,226, Level: 79
copyright violation
If region free BD's don't work also does that point to a faulty player?
Old 17-02-2009, 7:28 PM   #5
4,944, Level: 16
i have borrowed a back up blu ray and that works fine
but all my orignals dont seem to want to work, any ideas?
Old 18-02-2009, 6:35 AM   #6
skk3's Avatar
6,480, Level: 19
Points: 6,480, Level: 19 Points: 6,480, Level: 19 Points: 6,480, Level: 19
Activity: 14.9%
Activity: 14.9% Activity: 14.9% Activity: 14.9%
Thanks: Gave 68, Got 100
Does it say what region it is on the machine (usually where all the connections are...?)
Also, it may be worth finding the 'factory reset' option from the menus, selecting that, then unplugging the machine & starting again.........A bit tenous, I know, but worth a try.
KF it seems, is probably spot on. Good Luck!
Old 01-03-2011, 6:45 PM   #7
Abbafan1972's Avatar
1,538, Level: 8
Points: 1,538, Level: 8 Points: 1,538, Level: 8 Points: 1,538, Level: 8
Sorry to revive this thread, but I've just encountered the same problem today.
Bought a used copy of "Cloverfield" off an Ebay seller and it arrived today. I put it in my PS3 and it just made loud whirring sounds and wouldn't load at all (I don't think it's a problem with my PS3 as all other discs I've tried are ok )
Seems to play ok in my Panasonic BD60, after a bit of whirring and clicking, but when I tried it in the BD35, I got the same "copyright violation" message. I did think that the disc was a copy?
I did notice that the disc was a bit brown coloured on the one edge of the playable side, which did concern me a bit.
I was just looking for a bit of advice before I contact the Ebay seller.
Old 01-03-2011, 7:42 PM   #8
4,574, Level: 16
Points: 4,574, Level: 16 Points: 4,574, Level: 16 Points: 4,574, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 75, Got 56
It might be a firmware issue -- check the levels on the player then on the Panasonic web site. If there's an update available apply it, you've got nothing to loose, because it it doesn't fix the BR playback issue or even totals the player send it back for a refund.
BTW, you are playing BR originals not backup copies, right? I have heard of players choking on re-writeable media.
Clem
Old 02-03-2011, 9:42 AM   #9
1,538, Level: 8
Thanks. I have updated the firmware on the BD35 and it still won't play.
I have contacted the Ebay seller, no reply as yet.
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
10 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
6 prices from
 £94.95 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
Panasonic DMP-BDT110
8 prices from
 £99.99 Click to show/hide the offers
 Updated February 13th at 1:30pm. Prices include delivery.
