Back to the 3800 update
Well I have now viewed a number of titles on BR and DVD. I have continued to compare the DVD tot he Oppo. I still find the difference intriguing.
The Denon is sharper, and looks in some ways a little cleaner. The Oppo is a little softer BUT it has more depth and in comparison the Denon looks flatter. The ringing is similar on both, I have yet to play with the Denon to see if softening will help.
The Oppo looks marginally more filmic and is marginally more engaging.
Overall the Oppo is to me and others a preferable image on DVD, shame I can't have the benefit of both in one !
On to BR WOW............. I have seen lots of dems and seen BR on many occasions. However the Denon is the only player to date I have seen at home.
Here is the good news :
Greater image depth than anything I have seen at home (Even more odd that the SD is somewhat flat compared to the Oppo and even more so compared to BR). This is a quality that was very obvious at TLC using a 60" KRP Pioneer. I am looking forward to hooking up a cheap player to see a direct comparison at home.
This quality is a real sell for me. One thing I have always liked about BR is the detail, BUT on many an occasion in the dem rooms the image looks flat and digital.
The Denon at home is amazingly filmic and very very smooth. It looks like high quality 35mm film to my eyes on the right disc
I was truly in awe looking at Casino Royale. The action scenes were superb, no sense of smear or judder to my eyes. The fluidity and stability of the image coupled with the depth (on the right transfer) is very very engaging.
Another BR quality that the Denon exhibits at home is a lack of edge enhancement, it is sharp but not unrealistically so. When I look at a real life scene edges are not exaggerated and this is comparable to the Denon. There is real beauty to the presentation.
Now I have set up the analogue out and the player and new cables have had time to burn in (I don't want to start another debate, so if you don't accept that for whatever reason cables and equipment needs a number of hours to settle when new, just think of it as me waiting before passing judgement) I am very impressed with the audio side.
Compared to non HD processed through the AV8 there is an obvious increase in detail (As there is with SACD over CD in the world of 2 channel but I still prefer CD in most cases, some SACD recording to me sound strangely undynamic and a little bright) But coupled with this the weight and body to the recording is not reduced. The imaging is marginally improved (The AV8 is very good here) and there is a marginal improvement in realism.
It is also quite obvious that the recording quality on BR varies significantly. Timing and musicality is not reduced (Again a quality of the AV8). Dynamics are also very good. Certainly as good as the AV8 processing DD and DTS.
Overall a good HD recording is a genuine step forward over DTS, particularly around immersive surround scenes.
One thing I have confirmed is that using analogue out you do need the 10db lift. matching the AV8 settings for position and db adjustments on speakers (the Sonus Faber center is more sensitive than the fronts in my system) my DB meter showed perfect DB matching from all speakers at the listening position except the sub was 10db down until I lifted this with the 10db lift option.
More experimentation to do with the picture and the audio but at the moment I am very impressed with the BR picture and the audio. If I had seen the potential for the 'filmic-non digital' potential from players like this I would have ventured in to BR before waiting for disc prices to come down.
The audio is interesting as most HD sound tracks I have heard demoed before have tended towards the bright and harsh side. Maybe the higher quality audio processing was simply not available then. (I guess most dems were with sub £2k receivers)
I'll keep you all posted
