Sony bdps550 blu-ray
Old 15-02-2009, 11:03 AM   #1
1,133, Level: 7
Points: 1,133, Level: 7 Points: 1,133, Level: 7 Points: 1,133, Level: 7
Thanks: Gave 1, Got 0
Hi everyone
I currently have a 5.1 reciever/amp that only decodes dd &dts 5.1, and i was thinking of buying the SONY BDPS550 BLU-RAY player .
I heard that this player decodes dd true hd &dts master hd and has analog outputs, so if i connected this to my reciever via the analog outputs would i be able to hear dd true hd & dts master hd thru my speakers as the player would be doing the decoding.
ps. sorry if im being stupid but im not very good at this stuff
thanks in advance
Old 15-02-2009, 11:15 AM   #2
Eminent Member
kingfats's Avatar
106,213, Level: 79
Points: 106,213, Level: 79 Points: 106,213, Level: 79 Points: 106,213, Level: 79
Thanks: Gave 1,193, Got 7,647
Re: Sony bdps550 blu-ray
Originally Posted by nicholas2005 View Post
Hi everyone
thanks in advance
The player can send TrueHD/DTS-MA over the Multi-analogues.
All the best.
Old 15-02-2009, 12:15 PM   #3
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
make sure you can set the bass management up so this works with your gear.
Old 15-02-2009, 3:10 PM   #4
1,133, Level: 7
not really sure what you mean by setting up the base management,
at the moment i dont have a sub as my speakers deliver enough base for now, is that anything to do with it ?
thanks again for the help
Old 15-02-2009, 3:39 PM   #5
Illustrious Member
48,568, Level: 53
are your speakers set to full range?
Old 15-02-2009, 5:37 PM   #6
1,133, Level: 7
sorry you lost me ?
my amp has been st to "no sub attatched" so all base it sent through my speakers,
is that what u mean?
Old 15-02-2009, 5:47 PM   #7
Illustrious Member
48,568, Level: 53
not really but the end result will be the same however, probably not worth considering in your set up as your speakers will not be dealing with too much of the lfe channel anyway.
Old 16-02-2009, 7:03 PM   #8
1,133, Level: 7
sorry for my stupidity but when i connect to my amp using the analoge outputs, which ones do i use for the surround sound as there are 4, is it the ones marked surround or surround rear
Old 16-02-2009, 7:11 PM   #9
Eminent Member
kingfats's Avatar
106,213, Level: 79
Surround.
Old 16-02-2009, 7:14 PM   #10
1,133, Level: 7
thanks ,arent the ones marked surround for the ones at you side in a 7.1 setup this was kinda making me think it should be surround rear
Old 16-02-2009, 7:20 PM   #11
Eminent Member
kingfats's Avatar
106,213, Level: 79
Yes in a 7.1 setup if you 5.1 only use surround not rears (backs)
Old 16-02-2009, 7:21 PM   #12
1,133, Level: 7
ok thanks again for the help
Old 18-02-2009, 3:46 PM   #13
1,133, Level: 7
hi again
just changed my mind and baught the samsung bd-p2500 , so this should do the same job with the analogue outputs.
however i was just wondering can this player decode the hd audio and send it through the optical as this might be easier for me but i heard somewhere that it will reduce the hd to just normal dd & dts if i connect with the optical.
thanks in advance, this site rocks
Old 18-02-2009, 3:49 PM   #14
Assured Advertiser
MeanDorris @ AV Aficionado's Avatar
4,099, Level: 15
Points: 4,099, Level: 15 Points: 4,099, Level: 15 Points: 4,099, Level: 15
Thanks: Gave 271, Got 246
You are correct, you won't get the full hi res audio.
AV Aficionado supports AV Forums as an Assured Advertiser, please consider supporting us back.
OPPO 93/95 MultiZone/Region : JVC X30/X70/X90
Old 18-02-2009, 3:50 PM   #15
1,133, Level: 7
but i will with the analogue yes ?
Old 18-02-2009, 3:51 PM   #16
Eminent Member
kingfats's Avatar
106,213, Level: 79
hi again
Optical cannot support HD audio not enough bandwidth i'm afraid.
But,use optical out and choose Bitstream Re-encode the Samsung will re-encode "all" HD soundtracks to max bitrate DTS that's pretty cool.
Old 18-02-2009, 3:53 PM   #17
1,133, Level: 7
cheers, so basically which will sound better in my 5.1 amp.
analogue outputs or the optical ?
lol i should have just asked this question first
Old 18-02-2009, 3:55 PM   #18
Illustrious Member
48,568, Level: 53
depends on the quality of your kit. I like the optical feeding the better DACs of my processors personally.
Old 18-02-2009, 4:04 PM   #19
Eminent Member
kingfats's Avatar
106,213, Level: 79
Optical will give you excellent results plus just one cable and no worries over bass management either which can be hard to get right with the analogues......sometimes.
Cheers.
Old 18-02-2009, 10:19 PM   #20
1,133, Level: 7
can you explain a bit more about base management as i have tried with optical and analoge outputs.
the analoge seems much better however when there is lots of base with the analoge"ie explosions" my speakers crackle like hell,
i take it this is due to the base management ?
how can i sort this if possible ?
Old 18-02-2009, 10:34 PM   #21
Eminent Member
kingfats's Avatar
106,213, Level: 79
They shouldn't crackle/distort like that but with optical it's fine right?
Good post here from Nic on bass management and the analogues.
Old 18-02-2009, 10:49 PM   #22
1,133, Level: 7
yes with optical its fine .
ill keep messing with the settings and let u know how i get on
bye the way you have been more than helpfull
Old 18-02-2009, 10:51 PM   #23
Eminent Member
kingfats's Avatar
106,213, Level: 79
No worries definitely calibration setup issue with the speaker crackle though.
Old 18-02-2009, 11:20 PM   #24
1,133, Level: 7
ok sorted
i changed the output to bitstream audiophile and the crackling is gone,
but this confuses me as the handbook says this setting is so your reciever can decode the audio , but mine doesent decode dd hd or dts hd
Old 18-02-2009, 11:25 PM   #25
Eminent Member
kingfats's Avatar
106,213, Level: 79
ok sorted
Bitstream audiophile will send DD/DTS for TrueHD/DTS-MA over the optical,not sure why that setting would affect the analogues though?
Oh well,at least it fixed the speaker issue.
Old 18-02-2009, 11:42 PM   #26
1,133, Level: 7
gets better
just changed it back to pcm and its ok
think there is someting up with the player "see my other thread about speakers working then not working when i turn the player on off"
just turned the player to pcm then turned the player off/on and everything ok
then turned the player off/on and back to crackling, everytime i turn it off/on seems to be a hit or miss, wish i had just stuck to my guns and got the sony
perhaps next week when i can get a new 7.1 hdmi amp all my problems will be solved
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 12:30pm. Prices include delivery.
