I don't have a paper manual with my ex-display Region A model so had to download one from the web.
Would like to check with you guys that the settings I have chosen in the Set Up menu are correct. I have an older 5.1 analogue A/V receiver and using a Panasonic 1080i Plasma TV.
Here's what I have at the moment:
Audio
Digital Output PCM
PCM Down Sampling On
Dynamic Compression On
Speaker Set Up
LFE - On
[my speakers are Large]
Display
Movie Frame (24Fs) Off
Resolution 1080i
HDMI Set Up
Anynet (HDMI-CEC) On
HDMI Format TV
Sharpness Off
DVD Noise Reduction Off
Finally I've ignored the NETFLIX and PANDORA options - think they are web-based movie rental service applicable only in the States.
Does that all look about right?
Grateful for advice.
