firmware for oppo 983h
Old 21-09-2008, 10:44 AM   #1
6,861, Level: 19
Points: 6,861, Level: 19 Points: 6,861, Level: 19 Points: 6,861, Level: 19
Thanks: Gave 33, Got 0
hi m8s ive got the 983 from sweden now whats the latest firmware called and where can i get it the 1 thats on this player is 05.00.01.07 is this out of date
Old 21-09-2008, 11:09 AM   #2
t1m103's Avatar
7,136, Level: 20
Points: 7,136, Level: 20 Points: 7,136, Level: 20 Points: 7,136, Level: 20
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 185, Got 199
Re: firmware for oppo 983h
there is beta version here > http://www.oppodigital.com/dv983h/dv...e-11-0910.html
Old 21-09-2008, 11:11 AM   #3
2,716, Level: 12
Points: 2,716, Level: 12 Points: 2,716, Level: 12 Points: 2,716, Level: 12
Thanks: Gave 0, Got 15
I would not use beta, caused problems for me.
Old 21-09-2008, 11:12 AM   #4
6,861, Level: 19
is this for the european version oppo983 or the american
Old 21-09-2008, 11:13 AM   #5
6,861, Level: 19
so what is the latest euro version m8
Old 21-09-2008, 11:30 AM   #6
Eminent Member
kingfats's Avatar
106,202, Level: 79
Points: 106,202, Level: 79 Points: 106,202, Level: 79 Points: 106,202, Level: 79
Thanks: Gave 1,193, Got 7,647
Here mate.
Old 21-09-2008, 11:31 AM   #7
t1m103's Avatar
7,136, Level: 20
Activity: 2.7%
i think the firmware you have is the latest.
ive installed both us and european firmwares on my 981 without any problems.
Old 21-09-2008, 11:35 AM   #8
Illustrious Member
48,563, Level: 53
Points: 48,563, Level: 53 Points: 48,563, Level: 53 Points: 48,563, Level: 53
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 884, Got 1,284
I have put the 910 beta on this morning. All okay so far.
Old 21-09-2008, 12:48 PM   #9
6,861, Level: 19
where do you get this 910 beta then
Old 21-09-2008, 12:55 PM   #10
Illustrious Member
48,563, Level: 53
Activity: 0.8%
the same place as the ordinary firmware .
http://www.oppodigital.com/dv983h/dv983h_support.asp
It is immediately under the regular firmware. This one has been out 5 days now I think.
I would only recommend betas for those prepared to 'fiddle'.
Old 21-09-2008, 3:57 PM   #11
John Hodson's Avatar
7,597, Level: 20
Points: 7,597, Level: 20 Points: 7,597, Level: 20 Points: 7,597, Level: 20
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 165, Got 349
I've been using the beta for some days now and no problems whatsoever. Over at the AVS forums 983 guru Neuromancer has mentioned that with this beta being a very specific aspect ratio fix (that mostly affects PAL discs), it may be a while before it's incorporated into a 'full' fix.
Old 22-09-2008, 3:11 PM   #12
6,396, Level: 19
Points: 6,396, Level: 19 Points: 6,396, Level: 19 Points: 6,396, Level: 19
Thanks: Gave 9, Got 26
Yes, I too have installed the beta. Did it yesterday via the USB method. No problems upgrading.
The workarounds for the analog outs works! Great news!
Although not the most conveniant work around, but still.
I haven't had any problems yet with the upgrade. Of course one has to redo the region free hack (easy) and overall set up. Also note that this turns a PAL oriented player into a NTSC oriented player (defaults to 480p instead of 576p), so make sure your display handles NTSC (which most modern displays do).
Nevertheless, the upgrade is so far worth it as it fixes some issues I had with the player.
All that's left now is the subtitle issue (DivX truncations and SD DVD strikethroughs), and yes, a moving screen saver would be nice instead of the current shutting-down-the-signal implementation...
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
Samsung DVD-D530
3 prices from
 £35.90 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
8 prices from
 £89.95 Click to show/hide the offers
 Updated February 10th at 12:30pm. Prices include delivery.
