I wish Philips would produce an RCE recorder with decent reliability and we would not have this problem.
But they don't.
keep saying it. Ram never going to take off in a big way. Totally incompatable.
Considering RAM has had a 69% world take up a think it's safe to say it already has 'taken off'.
The next-gen format, BluRay, is going to be even more incompatible but no-one seems to bothered. Why? Because we will always have DVD-R for that.
Having to buy another DVD deck to backup is a joke.
Well not really as your then getting the functionality of a HDD/DVDR combo, i.e. record in best quality mode (using the hybrid VBR and making use of FR to maximise disk space), full flexibility to edit and then burn to highly compatible write-once media. You couldn't even dream of doing this with +RW.
All things said though you don't have to buy another DVD deck. If you have a half decent PC then you can simply get a DVD burner on your PC. In your case Harris (I seem to remember you already have one of these) all you need is a ROM drive capable of reading RAM disks - and all recent Toshiba DVD-ROM drives read RAM disks. You will then be able to burn your RAM recordings to DVD-R.
Of course the other alternative is to build a DVD-RAM library and not transfer the contents to DVD-R. I have a friend with the E30 who does this - he buys cheap DVD-RAMs for permament storage and, when he needs to lend out a copy, makes a copy to VHS (which ultimately is THE most compatible format).
