Originally posted by The Beekeeper Stick to Belden and 75 ohm CI plugs (Canare or cable pro), Elliot will sort you out here (and others shortly), anything less is a compromise |
Don't forget me Mr Beekeper
Another thread about component cables is
here
As The Beekeeper says, buy a well terminated cable, a good cable will last you for a few projector upgrades.
I can make something nice for you, but not for £50 for a 15M.
15M is a long component cable, so avoid a cheapy if you want a really good picture.
I have another make of a quality copper cored SDI coax that is cheaper than the Belden 1694A , Specs are good, used it many times for RGBHV cables etc, for the financially challenged
If I have enough left on the reel, I will sort something out for you nice and cheap. Always like to help people on the forums.
I might buy a reel of the
7710A in a few weeks if anyone would be interested in buying any really nice component cables.
Would cost a bit more than Bluejeans cables, but would be hand assembled in Yorkshire.
Mark.
