Well. I got an E50 last week. I am using the RGB passthrough on it for my NTL digitial.
I am fussy when it comes to quality. And I have also had a friend who knows his stuff look at it carefully with me. I tried on a number of channels with direct connection through my switch box from NTL and through pass through on the E50.
We have come to the following conclusions.
Their does not seem to be any noticable loss of quality on RGB passthrough on the E50 when it is switched off or in "Stand by" mode.
Their does seem to be a "Slight" loss of quality when the unit is on and in use watching NTL. But I mean slight.
Could this be because the RGB sockets are hard wired together and it switches to this form of connection when the unit is off ?
Or is it just interference when the unit is on or possibly running through the recording processing unit or what have you ?
Cant say for sure as I dont know enought about the unit. But loss of quality is pretty obvious on a 3 and a half foot plasma screen and I cant see any when it is in Standby mode which is what I have it in when I am watching NTL.
I use good quality 2 metre scart cables. There is also a scart switch box and RGB scart - Component converter between the E50 and my Plasma screen along with another 3 metres of quality RGB scart cable (The difficulties of wiring a load of AV gear
If any one else with an e50 and has different experience with RGB Pass through lets hear it. I can go back to direct connection from NTL digital quite easily if I felt there was a reason to. But the E50 has considerably simplified my setup. Dont have to Hardware switch between NTL and DVD now which is cool
