3 dvd players
Old 29-04-2008, 9:04 PM   #1
Illustrious Member
namuk's Avatar
40,906, Level: 49
Points: 40,906, Level: 49 Points: 40,906, Level: 49 Points: 40,906, Level: 49
Activity: 58.4%
Activity: 58.4% Activity: 58.4% Activity: 58.4%
Thanks: Gave 1,068, Got 2,470
3 dvd players
i use to have one dvd player . how i have three due too good deals and wot not.
does it do the players any harm putting them on top of each other? i never did like doing it anyway but i have no choice
any coomments
thanks
Old 29-04-2008, 10:05 PM   #2
Eminent Member
kingfats's Avatar
106,213, Level: 79
Points: 106,213, Level: 79 Points: 106,213, Level: 79 Points: 106,213, Level: 79
Thanks: Gave 1,193, Got 7,647
Re: 3 dvd players
Moved.
Old 29-04-2008, 10:14 PM   #3
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Points: 18,180, Level: 32 Points: 18,180, Level: 32 Points: 18,180, Level: 32
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 125, Got 1,022
Re: 3 dvd players
any coomments
thanks
If there are vents on the top,then dont stack.No vents,then stack away
Old 29-04-2008, 10:16 PM   #4
Ron240's Avatar
9,464, Level: 23
Points: 9,464, Level: 23 Points: 9,464, Level: 23 Points: 9,464, Level: 23
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 104, Got 258
Re: 3 dvd players
any coomments
Only oone,
why would you want to use 3 DVD players at the same time?
Old 30-04-2008, 9:53 AM   #5
4,445, Level: 15
Points: 4,445, Level: 15 Points: 4,445, Level: 15 Points: 4,445, Level: 15
Thanks: Gave 26, Got 10
Re: 3 dvd players
Even if they don't have vents, they'll still need to dissipate heat, plus the transport motors magnetic fields can interfere. So, in the interests of reliability, etc., try using some spacers, especially if the players have the usual tiny rubber pad feet. Maybe fit some much thicker adhesive rubber feet - eg., try Maplins.
Old 30-04-2008, 9:58 AM   #6
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Activity: 6.1%
Re: 3 dvd players
Another tip for isolating your gear is to cut squash balls in half and use them under your kit.
Old 30-04-2008, 2:45 PM   #7
Illustrious Member
namuk's Avatar
40,906, Level: 49
Activity: 58.4%
Re: 3 dvd players
Originally Posted by Ron240 View Post
Only oone,
one multiregion dvd player on blue ray player and a hd dvd player
Old 30-04-2008, 2:46 PM   #8
Illustrious Member
namuk's Avatar
40,906, Level: 49
Activity: 58.4%
Re: 3 dvd players
lol your having a laugh yea
Old 30-04-2008, 2:51 PM   #9
Illustrious Member
namuk's Avatar
40,906, Level: 49
Activity: 58.4%
Re: 3 dvd players
they will not be all on at same time. and never thought dvd/hd players got hot
Old 30-04-2008, 5:46 PM   #10
4,445, Level: 15
Re: 3 dvd players
All players produce heat, though some less than others. Some run cool enough that they don't need vents, but use the case as a heat sink to dissipate heat. Some don't provide adequate cooling with the result that they virtually cook the disc, and without optimal ventilation, can become quirky in some conditions. Manufacturers usually recommend minimum spacing around player to provide adequate convection cooling, or enough room for fan exhaust when forced cooling is used. High def players tend to have greater thermal energy output, so most have fans to provide forced cooling. Spacing other than at the rear, is less important for these. Stray magnetic fields from adjacent players can affect operation and performance, so spacing can help here. If you use more than one player simultaneously, vibration can cause problems, so again, isolation with feet such as the half squash balls mentioned, can help. Having said all this, I run stacked items with minimal spacing and have no problems.
Old 30-04-2008, 6:39 PM   #11
Illustrious Member
namuk's Avatar
40,906, Level: 49
Activity: 58.4%
Re: 3 dvd players
yea there not in a cabinet i have loads of room at back (6") and sides there on a shelf and onely running one at time. when i did run films through them discs were cold when taken out
Old 30-04-2008, 10:16 PM   #12
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Activity: 6.1%
Re: 3 dvd players
Laugh if you want,but they isolate vibration.
Old 30-04-2008, 11:32 PM   #13
Illustrious Member
namuk's Avatar
40,906, Level: 49
Activity: 58.4%
Re: 3 dvd players
thought you were taking the **** mate
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
11 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 8:30am. Prices include delivery.
