| Re: Video quality : Oppo 981HD or Yamaha S2700 or ..?
The DVD-S1700 apparently has the same video quality as the DVD-S2700, with the audio undergoing a massive improvement on the latter.
The S1700 is availible new for cheaper than a 981 too, although i'm waiting for the 983, which should be practicaly the last word in DVD video player, and will cost a similar amount to the 2700 currently. It won't be out over here for a while yet, comes out in the us on thr 10th.
It may be arguable that on these higher end picture produce a picture that really is only marginaly different and if your into using a DVD player as a universal disc spinner the 2700 will likely be a lot better for audio discs.
Remember that both yam and the 981 use farudja for the upscaling, which causes macro blocking on some displays, although I stress some, mainly DLP apparently, again it depends though.
