| Weird sound thing with old Toshiba player
I have a Toshiba SD220e which is maybe 6 years old I guess. It still works fine, but I've recently added an AV amp to the setup for the first time.
The Toshiba has a setting in the Audio Setup Menu for output format, either Analog 2ch, Bitstream or PCM. As my speaker system is 2.1 and I'm using a digital cable, I set it to PCM.
This works for most DVDs fine. However on one that I've discovered (a Spinal Tap edition) the sound comes out very weirdly - whenever the drums start, the rest of the sound dips, like it's being massively overcompressed and the drums are ducking the output.
By trial and error I discovered that this is fixed by setting the Audio Menu setting to Analog 2ch (even though I'm still using the coax cable!), but then for other DVDs no sound comes out at all!
Can anyone explain what is going on? And would this situation be fixed by having a newer DVD player?
Andy
