| Re: Pioneer DV600 owners - urgent help required (RGB colour shift?!)
Apologies for the double post, but this is an update, as well as a bit of a bump for any more assistance.
Well today I had the chance to try my DV-600 on another TV, this time a JVC AV28T5SK which was bought just a week ago (the actual model is very recent too I gather. Exactly the same results as my Panasonic TX28 DK1 (I envied the JVC's flat screen, but I don't think the total package was up to the quality of the Panasonic, nor the general image quality or adjustment/zoom options).
Well anyway, that's 4 PAL TVs which as far as I can tell, are all perfectly NTSC compatible. Having said that, NTSC compatability, in as much as colour standards shouldn't matter for RGB, as long as it can display 480/60 right? I know for a fact my Panasonic can do 576/60, so it's well within spec.
The problem totally threw me at first, and it got to the point where I was doubting myself. Had the colours been fine in PAL and not in NTSC (which you can select upon power up), I'd have accepted it as a NTSC compatability issue on my side, however when a PAL DVD player, set to PAL, playing a PAL disc on a PAL TV has these issues... Well that pretty much speaks for itself.
I couldn't offer up a decent theory, and it has been bugging the hell out of me, but I think I've got it now.
I'm speculating that the two players I've tried were made region free via a firmware update. I gather there is hacked firmware somewhere on the net. As I was navigating the options in the player, I came across "Parental controls (us)". So I now wonder if it was flashed with a hacked US firmware, and perhaps there are some slight differences in the electronics between the two, and this is what is causing the broken RGB output.
That seems to me, the most logical explanation. I am quite tempted to return this as faulty (which it is as far as I can see, considering it doesn't even play it's original region discs in something like RGB quality), get a new, region locked and untampered unit and see if that works how I expect. If it does, I think I'll try making it multiregion via the remote code (never tried it so some info/help would be appreciated) as this has the least chance of causing problems since it only removes a region check, rather than updating a complete firmware.
The downside though, is even if the region locked player is fine to start with, if I make it multiregion and the problem crops up again, then I am pretty much stuck with a unit that is of almost no use to me (as I have an old Sony multiregion I can fall back on and still get RGB scart).
Any comments/suggestions?
Cheers.
