15-12-2007, 9:40 AM
#1 (permalink)
Thanks: Gave 0, Got 2
40gb or 60 gb PS3 - Differences/better?
Finally decided to get myself a blue ray player, only to find there are now different versions of the PS3.
Are there any differences apart from the obvious 20gb and who is doing the best deals at the moment?
15-12-2007, 9:47 AM
#2 (permalink)
Thanks: Gave 914, Got 4,981
Re: 40gb or 60 gb PS3 - Differences/better?
Hi mate
Only a 40GB HDD, no backwards compatability, no memory card readers, 2 less USB ports.. and still no rumble controllers....
(according to GAME no SCAD playback or ethernet cable inc
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS SB12+, PS3, Oppo 983, S5000ES , XE1, Logitech 1000 remote, wildlife pond in back garden.
Be a man.........make a compost heap!
15-12-2007, 9:56 AM
#3 (permalink)
Thanks: Gave 180, Got 206
Originally Posted by kingfats
(according to GAME no SCAD playback __________________
Can confirm SACD playback is with the 60gb only. Can you still get the 60gb model?
All the best
Bri
15-12-2007, 10:00 AM
#4 (permalink)
All the best
Bri
Hi brian s
It's getting pretty scarce round my way now.
15-12-2007, 10:05 AM
#5 (permalink)
Hi brian s
Cheers KF
I don''t get to the PS3 shops very often but I don't think I've seen a 60gb in a while. Certainly they were running out when I bought mine which was at the end of Otober.
Best wishes
Bri
15-12-2007, 10:15 AM
#6 (permalink)
Thanks: Gave 166, Got 229
You can get them online. Heard its cause there is an 80gb model coming out
Tony
Pioneer PDP507XD ~ Onkyo TX-SR875 ~ AE Aelite 3's Front ~ 2's Rear ~ Centre ~ SVS 25-31 PCi ~ Sky HD ~Dual Format = Blu-ray + skyHD ~ Sony BDP-S350 ~ PS3 80GB ~ NOKIA N79 ~ CFC Member ~ PSN:chelski66
15-12-2007, 10:18 AM
#7 (permalink)
Tony
I've heard about that too. I wonder if that will be any different? SACD and DVD Audio?
Bri
15-12-2007, 7:04 PM
#8 (permalink)
Thanks: Gave 54, Got 195
The 40GB version is much quieter, runs cooler and consumes 25-30% less electricity. I find most 60GB PS3s to be too noisy for film play back.
The opinions expressed herein are not necessarily those of AV Forums, not necessarily mine, and probably not necessary.
15-12-2007, 11:03 PM
#9 (permalink)
Quite a few people have said this within these forums so I gather it's correct. If anyone's not that keen on the the "advantages" of the 60gb then go for the quieter 40gb model.
Regards
Bri
15-12-2007, 11:14 PM
#10 (permalink)
I have no problems concerning noise when watching movies. But if cost is a factor and its mainly for Blu-ray i would go for the 40GB.
Tony
15-12-2007, 11:22 PM
#11 (permalink)
I would have paid more for the 40GB version.
16-12-2007, 5:29 PM
#12 (permalink)
At last, a decent reason or two to go for the 40gb. To be honest it will be mainly for the blu ray player, although since I started looking some of the games do look quite appealing.
No doubt my 360 will sulk if its got to share space with a rival
16-12-2007, 8:14 PM
#13 (permalink)
Thanks: Gave 45, Got 31
As others have said, you lose backward compt, SACD playback, 2 USB on Front (4 down to 2) and 2 USB on back.
BUT ....
You gain the smaller die CELL processor, thus less heat thus less power consumption thus less fan noise, so better for Blu Ray playback.
You pays your money ....
Nikon D40 | 18-55 | 55-200 VR
flickr
16-12-2007, 8:16 PM
#14 (permalink)
Bri
Sony & DVD-Audio don't go!
flickr
16-12-2007, 8:26 PM
#15 (permalink)
Thanks: Gave 21, Got 124
isnt the 80gb version in the US only (not sure about Japan)
severely doubt we'll see it - although upping the hard disc from 40 to 80 would probably cost Sony about a quid.
I've got 2 US 60gb PS3s and yes the fan can be a little noisy at times, although rarely troubling during playback.
Also have a UK 40gb model but havent really used this enough to check its playback.
