AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Players (High Definition) > Blu-ray DVD Players
LinkBack Thread Tools Display Modes
Old 09-12-2007, 8:16 PM   #1 (permalink)
Thanks: Gave 2, Got 1
Question What US Blue-Ray Player Should I Get to upgrade Sony S300?
Going To Las Vegas on Boxing Day and i have been looking at buying a new Blu-Ray to update the S300 to support Bitstream Audio For DTS-MA. I only need it for Blu-Ray playback as i have an XA2 HD-DVD for upscaling all my other SD-DVD's. Looking at the Panasonic BD30 or Samsung 1400? Not sure if the extra £100 ish is worth it for the Panasonic or anyone recommend something else?
Hitachi 42PD7200, JVC DLA-HD1, US SONY BDP-S300, Toshiba HD-XA2, Denon DVD-1920, SKY HD, Onkyo TX-SR805, Bose AM16's, XBOX360. PANASONIC DMR-E50, Logitech Harmony 895. Bedroom : Mirai 32" LCD, Kitchen : 22" Mirai LCD
deerhunter09 is offline
Old 09-12-2007, 9:18 PM   #2 (permalink)
jon smith's Avatar
Thanks: Gave 127, Got 104
Re: What US Blue-Ray Player Should I Get to upgrade Sony S300?
The Panasonic seems to be getting decent reviews. Looking at the other threads you won't need a transformer either, which is nice.
The Samsung should be dead cheap though...
jon smith is offline
Old 09-12-2007, 10:17 PM   #3 (permalink)
Question Re: What US Blue-Ray Player Should I Get to upgrade Sony S300?
That the Prob! circuit city has the Panasonic For £250 ($500) or The Samsung for £150 ($300) an absolute bargain! , just dont know which way to go!
Old 09-12-2007, 10:58 PM   #4 (permalink)
Thanks: Gave 46, Got 44
hate to be presumptious but does this mean you will be getting rid of the s300? looking to take my first steps into HD at the minute and may be interested in taking it off your hands. If so drop me a line.
Cheers,
Michael
CyBeRkId2002 is offline
Old 09-12-2007, 11:09 PM   #5 (permalink)
sorry moving it to spain along with a cheap HD-DVD player and My Old Pioneer Amp to accompany my old plasma already there..
Old 26-12-2007, 1:16 AM   #6 (permalink)
I dont mean to hijack the thread, but I just got the s300 and was wondering what "Bitstream Audio For DTS-MA" mean. Ive got an older model sony 5.1 channel receiver with DTS, do I even need to worry about this new audio format?
svendawgg is offline
Old 26-12-2007, 7:10 AM   #7 (permalink)
kingfats's Avatar
Thanks: Gave 914, Got 4,981
Hi svendawgg
Bitstream is when the player sends the audio to the receiver to decode.
So to send DTS-MA Bitstream,you would have to have a 1.3 HDMI amp to be able to decode this audio format. :
The new HD audio tracks sound great and there is another way of hearing them by letting the player decode.....................what model Sony do you have and does it have multi analog inputs.
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS SB12+, PS3, Oppo 983, S5000ES , XE1, Logitech 1000 remote, wildlife pond in back garden.
Be a man.........make a compost heap!
kingfats is online now
Old 26-12-2007, 9:34 PM   #8 (permalink)
The unit that I have is a sony bd-s300. I do not think it has the 1.3 hdmi outputs. New tv is a 40" Sony Bravia v3000. The amplifier is a Sony STR-DE845 5.1 channel receiver. The speakers are assorted brands that I put together. Athena center, panasonic left and right, and Acoustech labs rear speakers. The brains of the setup are as follows:
XBOX 360 Core, 20 gig hd. The xbox is wired to the tv using a vga adapter, and then wired to the amplifier using a fiber optics wire. Just wondering if the bd 300 will be able to sound alright on the amp seeing as how it is an older amp anyhow and I do not need the newer audio formats.
Old 26-12-2007, 10:13 PM   #9 (permalink)
kingfats's Avatar
Hi svendawgg
The Sony will still sound great using optical with your amp,is this what you will be using?
Old 26-12-2007, 11:43 PM   #10 (permalink)
yes I will be using optical cables, thank you!
Old 27-12-2007, 4:13 AM   #11 (permalink)
one last question. Apparently the Blu-ray player isnt HDMI 1.3 compatible but my tv is. Does this even matter or can I still play all my blu ray dvd's without the 1.3. What difference does it make?? Will it affect the video or audio?
Old 27-12-2007, 7:04 AM   #12 (permalink)
kingfats's Avatar
Hi svendawgg
This will not affect you in anyway at all,mate
Your Blu-ray discs will play unaffected (audio/video) on your set-up.
HDMI 1.3 is only somehting to consider if you upgrade your receiver in the future.
blueray, player, s300, sony, upgrade
Refbacks are On
Thread Thread Starter Forum Replies Last Post
opinon's on sony bdp-s300 blu ray player SeeleyBooth Blu-ray DVD Players 12 26-11-2007 2:28 AM
Review: Sony BDP-S300 Blu-ray Player peterweg Blu-ray DVD Players 4 05-07-2007 3:41 PM
Sony BDP-S300 Blu-ray Player aandpwoodley Blu-ray DVD Players 18 05-06-2007 11:41 AM
Standard Sony Vaio v Blue Ray DVD player Gadjet Blu-ray DVD Players 4 13-02-2007 11:53 AM
sony wide screen kv32fq75/sony dav-s300/500-home cinema-any good??? stotty CRT Televisions 19 08-03-2002 9:43 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
