AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Players (High Definition) > Blu-ray DVD Players
LinkBack Thread Tools Display Modes
Old 08-12-2007, 8:44 PM   #1 (permalink)
Thanks: Gave 5, Got 0
Red face Another confused PS3 owner
Basically i just wanted to check if I had my amp and ps3 setup correctly: from what i gather the ps3 can only output Dolby True HD as Multi channel pcm- i find this a tad annoying because when i bought my ps3 i was rather hoping it would output it undecoded. Is it a hardware thing or a software thing (is it fixable via a firmware update?) and does anyone know about the rumoured DTS HD master audio firmware upgrade for PS3.
My main query though is that last night i got my hands on a copy of 300 and spent the following hours trying to get the most from it. What confused me is that when i set it to linear PCM (on the PS3) and then to Dolby True HD (on the disc) I get 48Khz (on both the amp and PS3) and a data transfer of 4.6mbps (ish). If i change from True HD to pcm (on the film) I get 48kHz and about 3mbps. Neither sounded particularly impressive over Dolby Digital (which tends to run at 640kbps).
I was under the impression that HD sound ran at frequencies like 96, 176, 192 kHz etc etc, someone educate me!
Incidentally DVD-A and SACD through my Pioneer 668AV-s sounds amazing yet the PS3 seems rubbish with SACD through it's HDMI??
Any thoughts?
Mission Elegante 5.2 (2 x e8as1 subs), Onkyo TX- SR 875, Sky HD, Pioneer 668av, PS3, Toshiba 32 WLT 58.
PS3 Gamer Tag: Cornelious03
stued is offline
Old 08-12-2007, 9:21 PM   #2 (permalink)
chic's Avatar
Thanks: Gave 63, Got 519
Re: Another confused PS3 owner
Any thoughts?
you are correct that the ps3 does the decoding and outputs as pcm, it is rumoured that the ps3 will never output the HD audio in bitstream format as some of the inards of the ps3 dont have the required chips to do so. Not a 100% sure on that though. Most soundtracks are 48khz and uncompressed pcm should give you a bitrate of 4.6mb up to 6.4mb depending on bit depth. Dolby true hd is avariable bit rate and will move between 0 and 3mb. What i have noticed with hd audio tracks is they are a bit quieter than standard dolby digital, but when you bump the volume up a bit they sound so much better that standard dolby digital. They have more dynamic range, more surround action and better surround placement. You should get a hold of casino royal the uncompressed audio on that will blow your socks off. I only have 300 on hddvd and i think the dolby true hd track on that souinds amazing. As fotr the rumoured dtsma update it was runoured to be before christmass. Heres hoping.
Samsung LE40R88BD ,Optoma hd70,Harmon Kardon AVR255,Mordaunt Short Avant 309i Subwoofer,Mordaunt Short Avant 906i Floorstanders, Mordaunt Short Avant 905i centre ,Mordaunt Short Avant 903i bipoles,Mordaunt Short 902i surround back ,Skyhd,PS3,XBOX360,HE-1,E-30,XBOX360,Samsung BDP1500
chic is offline
stued (09-12-2007)
Old 09-12-2007, 3:12 PM   #3 (permalink)
Nice one. I'll give that a try. Still a little confused about the whole sample rate thing though. I was expecting HD sound to be similar to SACD/ DVD-A (i.e between 96 and 192kHz) but i guess that is irrelevant. I assume it is just the amount of data being transferred over a given time (bit rate) which is most important??
stued is offline
Old 09-12-2007, 8:04 PM   #4 (permalink)
chic's Avatar
the hd audio tracks sound so much better than standard digital audio due to the extra bandwith, the dynamic range is better, there is better surround placement and there is so much more detal in all 5 channels.
chic is offline
confused, owner, ps3
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Help! Confused Nikon Owner.. martin99 Digital Cameras, Photography and Photo Editing 6 05-09-2007 8:34 AM
Confused AVR200 Owner garyjd Arcam Owners' Forum 3 05-04-2006 6:12 PM
New Plasma owner. Confused and worried (16bit color DVD's). Sn00chems Plasma Televisions 1 04-01-2006 12:46 AM
Confused/worried AuxiumHD50 owner DJ Splendid High Definition TV Hardware 8 25-07-2005 8:49 PM
Help a confused Arcam owner...! GW43 Arcam Owners' Forum 4 02-03-2005 1:02 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
