Help with a HD DVD Player
Old 05-12-2007, 12:24 AM   #1
2,798, Level: 12
Points: 2,798, Level: 12 Points: 2,798, Level: 12 Points: 2,798, Level: 12
Hi all, first post so here goes..
Ive got a little Philips 20" LCD Screen for the bedroom, its ideal as it fits on our drawers.
I want to add a DVD Player that will upscale the normal DVDs to HD, and also play DivX films ive got on my PC.
The one ive found is the PHILIPS DVP5980 as id like a Philips one to match to TV.
The inputs on my TV are Scart, RGB, S Video and DVi.
I know to produce an upscaled picture i need to use the HDMi output from the player, but the screen doesnt have that input.
Can i use one of these - http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
Will it produce a HD picture using that adapter to take the HDMi input into the TV via the DVi socket?
Any help appreciated
Russel
Old 05-12-2007, 8:51 AM   #2
11,437, Level: 25
Points: 11,437, Level: 25 Points: 11,437, Level: 25 Points: 11,437, Level: 25
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 257, Got 219
Re: Help with a HD DVD Player
You don't say whether your tv is HD Ready. As it doesn't have an HDMI input then it sounds like it isn't. If it is then it already upscales the picture to fit the screen. It is not very likely that an upscaling DVD player will do the job any better. Believe me I've got one and the effect is marginal on a 26" screen. On a 20" it would be undetectable. Upscaling DVD players do not magically turn normal DVD pictures to HD. They are a compromise situation that adds a few lines here and there. This picture will then be upscaled again by the tv (if it has a 720 screen). Quite often the result of this 2 stage process the effect is often worse,not better.
Old 05-12-2007, 12:01 PM   #3
3,027, Level: 12
Points: 3,027, Level: 12 Points: 3,027, Level: 12 Points: 3,027, Level: 12
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 15, Got 56
DVI should give a better picture than the other inputs, but you need to be sure that the DVI input is HDCP compliant, otherwise it won't work. Check the TV specification to find this out.
Old 07-12-2007, 4:03 AM   #4
2,798, Level: 12
yes it says HD ready on the TV.
Am i best to use the Philips DVD player ive seen then, sounds like it could make the picture worse?
And of the 3 inputs (Scart, RGB, DVi) The DVi input with the HDMi adapter will be the best picture?
thanks again
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 3:30pm. Prices include delivery.
