Originally Posted by mossym wouldn't think you're right there, i'd say his dvd player is doing the decoding for the analog outputs. they are only line level outputs though, they do need to be hooked up to 5.1 inputs on am amp.
however by using these you don't need to the amp to decode anything, you are only using the power stage |
Yes, you're right - I must admit I didn't read the first post correctly (
), but I still reckon that he's better with a single digital cable, co-axial or digital, to his amp and letting that do the decoding and amplification, which must be better than a spaghetti junction of analogue cables from the DVD player to the amp, as any AV amp he buys nowadays with 5.1 analogue inputs is going to have digital inputs anyway.
Cheers,
Martin.
