AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Players (High Definition) > Blu-ray DVD Players
LinkBack Thread Tools Display Modes
Old 03-12-2007, 9:03 PM   #1 (permalink)
Does the PS3 upscale to 1080P?
Does the PS3 standard dvd's to 1080 - I have read a few threads & some say it does and others don't????
by the sea is offline
Old 03-12-2007, 9:11 PM   #2 (permalink)
Thanks: Gave 0, Got 19
Re: Does the PS3 upscale to 1080P?
Yes, and very well with the latest FW update
borland is offline
Old 03-12-2007, 9:12 PM   #3 (permalink)
Bald Monkey's Avatar
Thanks: Gave 905, Got 558
AFAIK it does, via HDMI only of course.
My opinions expressed here do not represent those of the AV Forums or its associated websites
Forum Rules
Bald Monkey is offline
Old 03-12-2007, 10:35 PM   #4 (permalink)
Sorry to ask but what is an FW update & whare do you find it????
Old 03-12-2007, 10:41 PM   #5 (permalink)
kingfats's Avatar
Thanks: Gave 914, Got 4,981
Hi by the sea
You have to go into the Ps3 onscreen menu and click on updates and that will tell you if it needs updating.
You need a broadband connection and the Ps3 can go online and update via wireless connection.
Adds new features and fixes bugs.
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS SB12+, PS3, Oppo 983, S5000ES , XE1, Logitech 1000 remote, wildlife pond in back garden.
Be a man.........make a compost heap!
kingfats is online now
Old 03-12-2007, 11:00 PM   #6 (permalink)
Thanks: Gave 30, Got 2
Isd the version 2.0 update out yet?
Robdog is offline
Old 03-12-2007, 11:17 PM   #7 (permalink)
kingfats's Avatar
Hi mate
2.01 is the current one.
Old 03-12-2007, 11:25 PM   #8 (permalink)
Thanks: Gave 284, Got 1,491
FW = firmware.. Software which is written to EPROM ( a form of memory which can be written to) which contains the core of software which controls hardware
AS such any hardware whose firmware can be upgraded to better levels of functionally get firmware upgrades which don't ship with the hardware originally but latter version may have them
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline
Old 04-12-2007, 12:08 AM   #9 (permalink)
Thanks: Gave 7, Got 45
I for some reason cant get mine to upscale to 1080p, Blueray's play perfectly at 1080/24 but when i try a DVD it plays at 1080i.
Ive tried all the DVD upscaling options to no avail, if i go into Video settings>Video output settings and choose Automatic it says "Maximum resolution 1080p but if I choose Custom and tick 1080p the screen just goes blank for 30 seconds .
Ive played around with it but for some reason i cant get it to upscale to 1080p .
BTW im running the latest firmware with the PS3 connected via HDMI (obviously) to a Pioneer 436xde ...can anyone help
So long and thanks for all the fish
Attu is offline
Old 04-12-2007, 6:46 AM   #10 (permalink)
kingfats's Avatar
Hi Attu
I use to have the Pioneer 506XDE and that's what it did with me also!
You can't upscale to 1080p with SD dvd because the TV does not have the full resollution 1920x1080.
But Blu-ray will play just fine at 1080p/24 as your panel downscales the 1080p siganl to match your TV's native resolution.
Old 04-12-2007, 11:12 AM   #11 (permalink)
Originally Posted by kingfats View Post
Hi Attu
Hi Kingfats, thanks for you reply.
I know the Pioneer isnt a 1080 screen but why doesnt it just downscale an upscaled 1080p SD DVD image in the same way it does a Blueray image ?
The screen is capable of receiving a 1080p image it just doesnt make sense why it will do it with Blueray and not upscaled DVD ?
Ive got a Denon 1920 that can only do 1080i so Ive go no other 1080p source but if I connected a newer upscaling DVD player, say a Denon 1940 would that not allow me to upscale to 1080p either ?
I just cant see how the TV can differentiate between 1080p from Blueray and 1080p from upscaled DVD, saying that is it the TV thats doing it or is it the PS3 ? ....confused
Attu is offline
Old 04-12-2007, 11:25 AM   #12 (permalink)
kingfats's Avatar
Hi mate
I know what you mean mate................it use to do it on my 506XDE,Blu-ray fine but (like you say) 1080p no go with upscaled dvd.
Maybe were missing something!
I'll tell you what though,i bet it wouldn't make any difference anyway.
Cheers,
Old 04-12-2007, 11:52 AM   #13 (permalink)
I bet your right it probably wouldn't make any difference .
Its just that I know the PS3 is meant to do it and cant see any reason why it wont do it on my Pioneer Plasma, its some thing I keep going back to every couple of weeks to see if Ive done some thing wrong and just get frustrated with my self and the PS3 because I cant get it to work ...even if it probably wouldn't make any difference....i just want to see it do it
Attu is offline
Old 04-12-2007, 1:00 PM   #14 (permalink)
aniki's Avatar
Thanks: Gave 1, Got 65
....confused
The reason for this is simple. Mainly because people are using the term 1080p generically.
Pioneer screens will accept a 1080/24p signal.
Upscaling of SD produces a 1080/60p signal which the Pioneer doesnt accept.
"What is it? Its a Robot. But different, like a you know, Super Advanced Robot. Its probably Japanese"
aniki is offline
Old 04-12-2007, 1:05 PM   #15 (permalink)
kingfats's Avatar
Originally Posted by aniki View Post
Hi mate
My Pioneer accepts 1080i/60 and 1080p/60 signals.
1080p, ps3, upscale
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Can PS3 Upscale SD DVD to 1080p? Ruby Blu-ray DVD Players 27 11-06-2008 3:35 PM
