Originally Posted by Jobbypon Hi guys.
Anyone know if the Sammy 42Q97HDX is 'i' or 'p' ???????
I am buying the plasma this week, and want to know whether to buy the 5960 or 5980.
Ideally, I want to buy the 5960 as can get fron Argos and take back if not happy, but would this be ok with the Samsung telly or should I go for the 5980, and why !!!! ????
Please help asap, as I am keen to part with my money asap....
Cheers, Jobby.      |
It's a 720p set so can not display 1080p, the 5960 would be more than adequate for your needs. The only reason you'd get the 5980 instead is to future-proof yourself for when you get a 1080p set, but by then there would probably be better players out
You should really read up about 720p and 1080p, though. Your set is 720p "HD Ready" and has a screen resolution of 1024 x 768. 1080p screens are called "Full HD" and generally have a screen resolution of 1920 x 1080 so can provide better picture quality with a 1080p source. However a) they cost a lot more for a decent one, b) it's debatable whether it's worth it at 42" and c) unless you're into gaming many people say there's no point at the moment as 1080p material isn't too common over here.
I'm in the same boat as you as I've just bought a 720p 42" plasma, and I'm also planning to go and get the 5960 from Argos when I pick up my new TV unit!
