Is the UK 2.7 firmware here already?
Old 16-11-2007, 10:26 PM   #1
Thanks: Gave 6, Got 21
My Xe1 was updated to 2.5 when that firmware was launched
Thought i'd just check to see if anything was available, so went to the maintenance screen it confimed that my firmware is 2.5, but just out of curiosity I selected update (normally it just says "latest firmware uploaded ")
Guess what? this time it didn't and at this very moment it's updating!!!
I'll let it run it's course and report back but fingers crossed!!!!
Maybe Toshiba have snook it upon us on the quiet.
Regards Rob............................
klnc (17-11-2007), LOXjet (17-11-2007)
Old 16-11-2007, 10:39 PM   #2
Preeminent Member
kingfats's Avatar
Thanks: Gave 1,209, Got 7,638
Re: Is the UK 2.7 firmware here already?
Cheers mate!
I'll look forward to what you find out.
Old 16-11-2007, 11:15 PM   #3
It's done the download but it's now 2.7 woo-hoo!!!!!!!!
Perfect lipsync, perfect, HDMI handshaking Dolby Digital plus , Dolby HD,
and DTS-HD master audio confirmed by playing T2
Toshiba thank you
Regards Rob........................:clap :
Old 16-11-2007, 11:27 PM   #4
Thanks: Gave 3, Got 22
My EP-10 is DL an update as off now - Anyone have details of what 2.7 does for the EP-10?
Regards
Peter
Old 16-11-2007, 11:29 PM   #5
Thanks: Gave 6, Got 9
Welcome to the "2.7 club"
Our first official UK member!
Old 16-11-2007, 11:32 PM   #6
I would think the EP10 will get the same updates as the Xe1
regards Rob...........................
Old 16-11-2007, 11:38 PM   #7
jackal
Posts: n/a
Toshiba thank you
Cheers for that I'll update later.
Old 17-11-2007, 12:07 AM   #8
Eminent Member
brian s's Avatar
Thanks: Gave 859, Got 1,824
Be very keen to know the results.
All the best
Bri
Old 17-11-2007, 1:36 AM   #9
Interesting ................. I just tried to update my US 2.7 firmware XE1 to the Official UK 2.7 firmware via internet connection.
It reported that an update T2.7 was available, do I want do update. I selected yes and it then reported that the upgrade had already been installed.
An indication perhaps that the US XA2 2.7 and UK XE1 2.7 firmwares are indeed identical?
Old 17-11-2007, 1:43 AM   #10
Thanks: Gave 10, Got 51
Havnt noticed any nasties with this update. Tried Hd dvds and sd dvds, no lipsync errors.
Regards
John.
Old 17-11-2007, 1:45 AM   #11
MI55ION's Avatar
Thanks: Gave 415, Got 482
You're right there, when I tried to update I got this message:
The software has already been updated.
The update process will end.
Great stuff!
Old 17-11-2007, 1:51 AM   #12
Hopefully, this means that we will be able to update to future official UK XE1 firmwares (V2.8 forced 1080p/24 output perhaps?) without any problems!
Old 17-11-2007, 2:01 AM   #13
jackal
Posts: n/a
Apparently forced update will never happen unless the studios decide to flag the disc main presentation as such. This has been stated on here.
I doubted it, but just talked to an old mate in the US (works for Oracle in a senior position) and this is apparently true.
She said 1080p 24 was an unforeseen add on????????
Seems to me that HD DVD has been caught on this one
Beyond my area of knowledge, so who knows.
Old 17-11-2007, 7:34 AM   #14
Preeminent Member
kingfats's Avatar
Toshiba thank you
Hi tdm34
Cheers for the heads up,mate!
Updating now...........
Old 17-11-2007, 7:50 AM   #15
Thanks: Gave 27, Got 42
How can you be certain if your player was trying to upgrade from the US or the UK internet servers ? If there is a emthod of checking I'd very much like to know how to do it.
If having loaded the USX A2 2.7 sets the player up to reference the US servers then you would expect to see a message tellling you that the update had already been installed, so I'm not certain that this really tells us that the two firmware versions are exactly the same.
Although I agree it seems to be a very strong possibility that there is now just a single unified version.
Old 17-11-2007, 7:57 AM   #16
Preeminent Member
kingfats's Avatar
Hi mate
We can't download from the US servers,only the UK.
Old 17-11-2007, 8:00 AM   #17
I know that its been stated on the forums that a forced 24P mode will not appear until the studios build in support for it on individual disks.
However the reasons to backup such a view seemed to me to be rather wooly. Or at least I could not see a firm basis for such a view (my appologies though if I have missed something).
I also don't wish to denegrate you old friends view / feedback and can imagine that she knows a great deal about databases given his employeer but does it follow that he is anymore in the know as regards the in's and out's of 24P processing in HD-DVD ?
I'm intruigued by the statement that 1080p 24 was an unforeseen add on.
Seems incredibly unlikely to me that this is the case. Its been part of the HD-DVD standard from the start. Afterall someone decided that they would author the disks in 1080p 24, so it would logicaly follow that they would think that they would eventualy like to pull this information straight off the disk at some point rather than having to frame rate convert all the time.
Lets face it 1080p 24 has been the holy grail of the display industry for a long time, so I really doubt that its an afterthought.
I could however see how someone may build it into a standards spec before they had fully worked out how to implement it at a detailed level.
So I'm not convinced that this is a major big deal to implement.
Afterall the players can now output 1080p 24 and when set to do so can detect (sometimes incorrectly based on the displays EDID) when a display device cant accept 24p and drop back to the next lowest option. How difficult can it be to implement some code that stops the player from falling back ?
Maybe there is something in the spec that makes this more difficult than I can imagine. Would love to see the HD-DVD specification.
Old 17-11-2007, 8:12 AM   #18
Preeminent Member
kingfats's Avatar
Hi jackal
Robert from AVS,says FORCED 24fps will be on the next update!.
I don't need it myself,but if anyone does i hope he's right...................and he does seem to be right quite a lot.
Old 17-11-2007, 8:36 AM   #19
Preeminent Member
kingfats's Avatar
Just updated the UK 2.7 firmware and everything went smooth!
Here's a pic of the new option,please don't collapse with excitement.
I'm off to test how TrueHD sounds sent Bitstream...................oh wait,i need a new receiver.
Cheers.
Old 17-11-2007, 10:24 AM   #20
Preeminent Member
kingfats's Avatar
Just tested some HD dvd and can confirm 1080p/24 now works flawlessly.
Old 17-11-2007, 11:05 AM   #21
Thanks: Gave 6, Got 32
I just tried to update my XE1, that has the australian region free 2.501 firmware on it.
I got a message saying that the software was up to date.
So it does look as though the australian firmware is set to look for updates on a different server to the european one.
Guess I'll wait until the ISO is downloadable.
Old 17-11-2007, 11:37 AM   #22
Thanks: Gave 10, Got 23
I am going to update my XE1 with 2.7 , but doesn't have the australian region free 2.501 firmware on it. can i still do that later after i have done 2.7 or will it not let me and i should do it before 2.7?
thanks
Old 17-11-2007, 11:40 AM   #23
Preeminent Member
kingfats's Avatar
thanks
Hi mate
I would have thought you would have to do it before 2.7.
sunnyhd (17-11-2007)
Old 17-11-2007, 12:06 PM   #24
Thanks: Gave 118, Got 423
You could install the US version right now, or wait for the ISO to be downloadable.
What is interesting is that the Australian region free 2.501 firmware, region freeing is maintained AFTER people installed 2.7. This would indicate that this firmware, different to normal Toshibe releases, writes in a part of the firmware that does not normally get changed.
It will be interesting to see if those who used the US version of 2.7, now get their firmware updates from the US server (and we will know this if the update is available sooner than in the UK), or still from the UK server, because the normal firmwares do not change this bit for the firmware.
Old 17-11-2007, 12:12 PM   #25
tee tee is online now
tee's Avatar
Thanks: Gave 0, Got 50
Any idea when the UK 2.7 update ISO will be downloadable?
Old 17-11-2007, 12:19 PM   #26
Preeminent Member
kingfats's Avatar
Hi mate
I have a spare 2.7 (US) disc if you want it mate!
PM with your details ,if you want me to post.
Works fine on UK player,been confirmed by lots of people.
Old 17-11-2007, 12:24 PM   #27
tee's Avatar
Sweet! PM-ing now
Old 17-11-2007, 12:37 PM   #28
Preeminent Member
kingfats's Avatar
Sweet! PM-ing now
Old 17-11-2007, 1:47 PM   #29
Thanks: Gave 58, Got 18
what i wanna know is,how's the 1080p/24 with regular dvd's now at 2.7? perfect??
what's the release note for 2.7?
Old 17-11-2007, 2:04 PM   #30
Preeminent Member
kingfats's Avatar
Hi Jurgennoppe
1080/24 should not be used for SD dvd.
Have tried a load of SD dvd's today and all working perfectly at 1080p.
