Philips 963SA digital out
Old 26-01-2003, 4:20 PM   #1
4,135, Level: 15
Points: 4,135, Level: 15 Points: 4,135, Level: 15 Points: 4,135, Level: 15
Thanks: Gave 1, Got 2
Can anyone help me, I think I may have a problem. I have been wanting a good PAL prog scan DVD player for a while now, and having had a limit 9900SE for the past 2 weeks. I decided to get a 963SA. I thought the limit was ok for a budget player, but it went back due to build and sound quality.
Yesterday I got a 963SA, initial thoughts were good. Improvements in sound and build. However 2 things got my attention. 1) the picture seems more grainy, especially in dark scenes, compared to the limit. Whether this is as it shows more detail is to be further investigated.
And 2) Which is the question. I cannot play CD's through the optical out to my Denon AVR 2802. I know SACD's wont play, but CD's should. Does anyone have any advice? I am thinking about returning it and getting a Denon DVD 2800 mkII. What should I do?
Old 26-01-2003, 5:09 PM   #2
magking's Avatar
5,071, Level: 16
Points: 5,071, Level: 16 Points: 5,071, Level: 16 Points: 5,071, Level: 16
Ok, two things I can think of:
1. Check your amps digital input assignment. The digital inout you use has to be set to DVD. And set the amp to auto on the signal detection mode.
2. Check the Philips digital audio out, in the setup menu, this has to be on.
BTW. IMO, if you should decide to return it, dont get the 2800mkII, get the 3800.
Old 26-01-2003, 6:18 PM   #3
Maqui123
Posts: n/a
Probably CD upsampling is on. Disable it or lower to 96kHz (if yor amp can handle that).
Regards
Old 27-01-2003, 12:15 AM   #4
4,436, Level: 15
Points: 4,436, Level: 15 Points: 4,436, Level: 15 Points: 4,436, Level: 15
Yes, reduce your upsampling if you are playing CDs via the digital connection. If this doesn't work, use a coaxial digital connection which supports higher resolution than optical.
....and the grainyness is probably caused by TrueLife being set too high in the "Digital Crystal Clear"(progressive) menu. You should also select "Personal Colour" in the Colour Settings menu and either zero it out(and adjust your display) or adjust that to get a good picture.
Cheers,
Old 27-01-2003, 1:23 PM   #5
7,412, Level: 20
Points: 7,412, Level: 20 Points: 7,412, Level: 20 Points: 7,412, Level: 20
Thanks: Gave 5, Got 20
Is 'personal colour settings' and 'true life' available when using component output?
I too noticed that grainy films are made worse with the Philips prog scan
Old 27-01-2003, 1:44 PM   #6
45,485, Level: 52
Points: 45,485, Level: 52 Points: 45,485, Level: 52 Points: 45,485, Level: 52
Activity: 21.6%
Activity: 21.6% Activity: 21.6% Activity: 21.6%
Thanks: Gave 378, Got 854
...maybe you are seeing the grain that was already there, but you couldn't see before on 'lesser' DVD players ;P
As mentioned though, try setting Trulife to 0.
Old 27-01-2003, 6:09 PM   #7
4,436, Level: 15
TrueLife does work on the component out in progressive mode. True life is one of the functions of the FLI2300 chip.
The "colour settings" do not affect the component video output.
Cheers,
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 1:30pm. Prices include delivery.
