| Re: Cambridge Audio DVD89 Problem, help!
Hello
Not sure if this will help but this is the problem I had (have). I bought a 540D v2 recently and found that some discs would just sit there (I moaned about this on another thread). To be fair though when I considered the discs, they were homemade discs (on DVD-R 16x). I was ready to return the unit when I found that with a problem disc if I pressed the title menu button on the remote the dvd menu would appear on screen and then all worked fine. I do not recall having this problem with pre-recorded discs. I have decided to keep the machine as am very pleased with sound and picture and this issue is not a problem to me.
Anyway sorry to hear of your problems and hope you get a solution if this is no use to you.
