Do upscaling DVD Players benefit S-Video output quality?
Old 31-08-2007, 11:24 AM   #1
1,960, Level: 10
Points: 1,960, Level: 10 Points: 1,960, Level: 10 Points: 1,960, Level: 10
Thanks: Gave 16, Got 0
I'm relatively new to this forum, so apologies if this has been asked in the past.
On my current setup, I have a standard definition DVD player hooked upto my Toshiba 48-inch CRT Rear Projection TV via 4-pin S-Video. I am extremely impressed with the quality and sharpness of the picture. But would I notice an improvement if I bought an upscaling DVD Player and hooked it up the same way? Or does upscaling only benefit component signals? (My TV has only 4-pin S-Video, SCART, and RCA Composite connections, no Component).
Thanks,
Old 31-08-2007, 11:26 AM   #2
Senior Moderator
LV426's Avatar
42,395, Level: 50
Points: 42,395, Level: 50 Points: 42,395, Level: 50 Points: 42,395, Level: 50
Activity: 37.1%
Activity: 37.1% Activity: 37.1% Activity: 37.1%
Thanks: Gave 1,530, Got 1,592
Re: Do upscaling DVD Players benefit S-Video output quality?
SVideo will only carry standard definition TV. Any upscaling in your source will have its output limited to HD MI and/or component. And in any case, whatever the upscaled resolution is - your TV will need to be able to handle it. Can it?
Old 31-08-2007, 11:46 AM   #3
Mitchaa
Posts: n/a
Upscale only works with HDMI cable and will upscale from 480-720. (If your tv is HD ready 768p) If you have a 1080p television, it will obviously upscale to 1080p
Thats the way i understand it anyway.
Old 31-08-2007, 11:51 AM   #4
1,960, Level: 10
Yeah I doubt my TV will have a high enough resolution then because its 10 yrs old....
Old 01-09-2007, 12:37 PM   #5
5,828, Level: 18
Points: 5,828, Level: 18 Points: 5,828, Level: 18 Points: 5,828, Level: 18
Thanks: Gave 5, Got 361
Upscaling also works via Component.
If you're using S-video and a standard TV then upscaling features will not be used, even if you use SCART RGB.
I doubt you'll notice difference between a Toshiba DVD player that's a few generations old, to a new Oppo 981 with SCART RGB.
Powered by
 Latest popular product prices
Toshiba SD5010
7 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
9 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Samsung BD-D5500
8 prices from
 £114.95 Click to show/hide the offers
 Updated February 11th at 4:30pm. Prices include delivery.
