hi chris57
tbh i was recommended to look at these players from afriend of mine, but really i,m not sure which ones i should be looking at, all i want is to play divx and p0lay throught more than one sound source and other things, is it possible you can recommend me some and is it possible to catch u on msn as it will be easier to ask you some questions pls.
QUOTE=chris57;5243039]Just a quick question why when you are spending megabucks on a lovely TV screen do you then only want a budget DVD player?
Have a read of the threads on the 5980/5960 over at avsforums where you can get the answer:-
http://www.avsforum.com/avs-vb/showt...4#post10997644 http://www.avsforum.com/avs-vb/showt...&page=16&pp=30
for that budget player/s.[/QUOTE]
