Anything cheaper than a toshiba 900e dvd player
Old 08-12-2002, 12:48 PM   #1
8,412, Level: 21
Points: 8,412, Level: 21 Points: 8,412, Level: 21 Points: 8,412, Level: 21
Activity: 12.1%
Activity: 12.1% Activity: 12.1% Activity: 12.1%
Thanks: Gave 21, Got 15
I have a toshiba 900e dvd player and i think picture quality is awesome, but im trying to get my finances in order, so i was thinking of selling the toshiba 900e and buying a cheaper player.
Is there a cheaper option that would give me as good a picture ?
How about the cheaper toshibas, preferably in gold to match my amp..
Old 08-12-2002, 2:01 PM   #2
gringottsdirect's Avatar
10,820, Level: 24
Points: 10,820, Level: 24 Points: 10,820, Level: 24 Points: 10,820, Level: 24
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 3, Got 13
Personally, keep the 900.
If you sell it you may be able to buy a Philips DVD-963SA but unless you need proper Pal-Progressive, why bother.
The Toshiba is particularly well built, the cheaper Toshibas won't be as good so will any cash difference you gain be worthwhile?
Save money by not smoking / drinking / indulging loose women.
Old 08-12-2002, 2:15 PM   #3
8,412, Level: 21
Activity: 12.1%
Thanks for the reply gringottsdirect, i dont smoke, dont drink alot, and not having much luck with loose women at the moment !
I bought my player from leconcepts, and i have compared the specs for the 900e for £699.99 with the 520e for £249.99 a difference of £450 !
Specs for the 900e are:
Hyper Anti-Alias Filter reproduces 540 horizontal
lines of resolution
Dolby® Digital/dts® Digital compliant
DVD//VCD/CD/CD-R/MP3 Playback
HDCD Precision Filtering and Decoding
10-Bit 54 MHz Advanced Video D/A Converter With High Resolution Filter
1.2mm Steel Chassis with Reinforced Copper Shielded Cabinet with a High Mass Vibration Resistant Cabinet and a solid Aluminium front panel
Concealed disk tray reduces contamination and minimises disturbances
ColorStream Progressive Scan Component Video Outputs
Built in Dolby® Digital/dts® Digital Decoding (6 ch output)
Spatializer® N-2-2 Virtual Surround Sound
3D-Digital Noise Reduction
Navi Control and Virtual Remote Control
Luminous Remote with Jog Shuttle
System Standby when idle after 20 minutes
Dynamic Software firmware upgrade
Bit Rate Display, Display Dimmer
Video Specification:
Progressive Scan (3:2 Pulldown) on NTSC and Pseudo PAL
(eliminating artefacts and jagged edges)
10-bit/54MHz Video Signal DAC for high-quality DVD
(twice the processing power of all other DACs)
Hyper Anti-Alias Filter @54MHz
(offering 540 lines of horizontal resolution)
4:4:4 Video up-sampling (colour purity, detail and resolution)
3D DNR circuit (reduces low level noise)
3x Picture Zoom (x1.5;2.5;3.5)
Still Play (Field or Frame with Auto)
Still Step Play Forward and Reverse
Slow Motion Playback
Audio Specification:
Neo Multi-Bit Delta Sigma D/A Converter for 192KHz/24 bit compliance (high jitter resistance and low noise levels)
Mega Resolution Parallel DAC for a linear response over a dynamic range greater than 120dB (total harmonic distortion less than 0.0006%)
High Performance audio components (specificaly chosen for their low noise characteristics and audio fidelity)
Dual 96KHz/24-bit Audio DAC for superb sound quality
Video Off Function increases Audio Clarity
Dolby® Digital/ dts® Digital Decoding
Dolby® Digital and dts® Digital Outputs
Output Terminals: (Gold Plated)
Digital Optical Output, Digital Coaxial Output
DVD Audio Out ( 6 Channels)
Analog Audio Output x1
Scart (RGB) Output x1
S-Video Output x1
Component Video Output x1 (Progressive/Interlace)
Composite Video Output x1
Built in Dolby® Digital/dts® Decoder (6 Channels)
specs for the 520e are:
lines of resolution
DVD/SVCD/VCD/CD/CD-R//MP3 Playback
Digital Photo Viewer
Display digital photographs Konica® , Fuji® Photo, Kodak® Photo CD as well as PC JPEG files
An intuitive on screen display allows the user to create customized slideshows with a few simple clicks on the remote
EAM/Dialogue Expander (NORMAL; 3-D;DIALOGUE)
Bit Rate Display
Display Dimmer
Progressive Scan (3:2 Pulldown) on NTSC playback
Black Level Expansion and PLUGE
Mega Resolution Parallel DAC for a linear response over a dynamic range greater than 108dB (total harmonic distortion less than 0.002%)
High Performance audio components (specifically chosen for their low noise characteristics and audio fidelity)
Dolby® Digital Decoding
Output Terminals: (Gold Plated):
S-Video Output x1
Built in Dolby® Digital Decoder (6 Channels
Can anyone tell me what the difference is between the 2 with regards to picture and sound quality ?
Powered by
 Latest popular product prices
Toshiba SD5010
7 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
9 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £89.95 Click to show/hide the offers
Samsung BD-D5500
8 prices from
 £114.95 Click to show/hide the offers
 Updated February 11th at 9:30am. Prices include delivery.
