When I pause a film in the above DVD player and then restart it I get a line across the middle of the screen (similar to a noise line on VHS). Before pausing there was no line and the only way to get rid of it is to power the unit off for a couple of seconds. Once restarted the picture is fine.
Also when playing a DVD-A disk (Queen - A Night At The Opera, the only DVD-A I have) it plays the disk as a DVD (DVD screen shows DVD not DVD-Audio as it should) and will only play back with the amp (Denon 3802) decoding the DTS signal on the disk. All the analogue outputs are connected and the leads have all been tested.
DVD video is connected to amp to plasma by component and audio via optical.
Is there a problem with the DVD player or am I doing something stupid
Mark.
